Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
Breathing
Old Jan 28, 2010 | 12:16 AM
TimC's Avatar
TimC
Default Breathing
As stupid as this sounds, what is the correct way to breathe when training.
Ie, in through nose at beginning of a rep, out through mouth at end of rep?
Also for the fighters, do you take one big breath in then release everytime you punch kick?
Stupid I know, but if you dont ask you dont find out
Old Jan 28, 2010 | 06:51 AM
mondeomad's Avatar
mondeomad
Thumbs up Breathing
Let me tell you that breathing plays an important part in exercise and relaxation. When your respiratory muscles are strong, you are capable of taking in more oxygen per breath. As a result, you can get greater amount of oxygen which your body needs for the production of energy but also recovery.
For just those two reasons
more energy
greater recovery
You clearly can see how important breathing is and that it will make a difference in your training.
But that's not all! Follow me here...
The stronger your respiratory muscles are, the more effective your cardiovascular endurance. Improving the strength of the muscles involved in breathing you can reduce the onset of fatigue and recover faster. In most cases, respiratory fatigue occurs before cardiovascular fatigue; thus, your breathing is directly related to your endurance as well as your lifting.
Obviously, how you breath during exercise is very important during the execution phase. New trainees should:
exhale thru the sticking point
inhale during the less strenuous portion of the lift
[Sticking Point is defined as the transition from the eccentric to the concentric contraction. Also know as the amortization phase.]
And this is just the start!If you pick up any article or go to most fitness sites and forums they will tell you that holding your breath under any circumstances is dangerous.
Now if you were to hold it for 8 seconds or more, that's true. The internal pressure in the chest and abdomen increases when you hold your breath on exertion.
If it increases greatly, it can squeeze down on the blood vessels shutting down blood and oxygen to and from the heart. When this happens you can black out. This is rare and only on maximum exertion.
Okay, so that is dangerous, holding your breath during maximal exertions for long segments.
But can you hold your breath as an advanced trainee and actually increase the weight you lift?In fact you can with a little technique called the Valsalva Maneuver. This involves expiring against a closed glottis, which when combined with contracting muscles of the abdomen and rib cage muscles, transforms your trunk into a stable and stronger support for some movements.
Often in advanced trainees, there are appropriate times in which you can hold your breath on the exertion and provide up to 20 percent greater force, stabilize the spine and prevent lower back injuries.
In fact, this little trick can transform your whole trunk, sometimes your whole body, into a stable unit against which your hips, arms and shoulders can move more effective.
Of course this Valsalva Maneuver assumes that you are:
an advanced athlete
without cardiovascular problems; high blood pressure or heart problems
do not hold your breath for more than a few secondsInhaling and holding your breath comes naturally in many sports
Using the Valsalva Maneuver is simple. You just:
Inhale during the less strenuous portion of the lift
Exhale after you have passed the sticking pointThat's pretty much it. Take for example a heavy set of squats
Picture yourself doing a very heavy squat and you are coming up out of the down position very slowly. The amount of pressure being built up is quite great. To relieve some of the pressure you would exhale slightly thru pursed lips.
But don't let all the air out!Not until you have passed the sticking point or the most difficult portion of the exercise.
Clearly exhaling after the sticking point is important to relieve the built-up pressure.
My point is: The key is to be sure that you exhale after passing the sticking point, not before.
Proper breathing is essential in successfully executing strength movementsArticle Submission, especially when handling heavy weights.
Old Jan 30, 2010 | 08:10 PM
dave cos4x4's Avatar
dave cos4x4
excellent first post,very informative.
Old Jan 31, 2010 | 03:56 AM
TimC's Avatar
TimC
Which was copied from a search in Google, as I found the same one just after posting. Still useful though.
M K
13
Jun 24, 2005 03:33 PM
RSKim
Feb 4, 2005 01:12 PM
andyescos
12
Feb 1, 2005 07:28 AM
Phil
Dec 13, 2004 04:05 PM
GrahamM
13
Jul 3, 2004 03:24 PM
