Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
fiesta st 150 problems eac fail abs ???
Old Oct 11, 2013 | 11:14 PM
tajturbo's Avatar
tajturbo
Default fiesta st 150 problems eac fail abs ???
hi guys iv got a 2005 fiesta st and its doing my head in . the abs & handbrake light is on all the time & the mileage display flashes eac fail .
iv changed a throttle pedal & still the same . iv tried 2 throttle bodies still the same ? any ideas guys ? iv put it on a snap on diagnostic and got the following fault codes . u1900 , p0403 egr related but car has not got one , p0073 ambient air temp sensor circuit high (cant seem to find a air temp sensor) . iv changed the plugs aswell but its abit lumpy slight misfire on idle .
Old Oct 11, 2013 | 11:36 PM
GVK.'s Avatar
GVK.
Have you had the ABS/ESP codes read?
I'd advise getting all the codes read (engine ECU, ABS/ESP) on a Ford IDS, this will give the correct fault codes and descriptions.
Ambient temp sensor is behind the front bumper in the centre. (bumper needs to be removed to access)
U codes are faults over the can-bus communications network.
If it was throttle pedal/body you'd have a throttle body/pedal code.
According to ETIS Pre 2/2006 had EGR valves, it's inbetween the coil pack and throttle body (if fitted).
Old Oct 12, 2013 | 10:14 AM
tajturbo's Avatar
tajturbo
iv had a look in engine bay and the egr valve is not there . don't know if its been blanked but the pipe that goes to it looks like its got a blocker on there also and I cant seem to find the plug that egr plugs into . iv been told prefacelifts do have egr aswell ?
but would any of these give my car the eac fail ? I been told by a ford breaker that for the abs problem I would need a new abs pump/module ? its ment to be a common fault on prefacelifts ?
Old Oct 12, 2013 | 05:16 PM
GVK.'s Avatar
GVK.
If the EGR has been removed and not 'coded out' of the ECU it will expect it's there and put in a fault.
No point guessing and changing random parts, it needs diagnosing properly.
Old Oct 13, 2013 | 03:05 PM
tajturbo's Avatar
tajturbo
dont suppose you know anyone in Birmingham that would come out and diagnose it ?
Old Aug 3, 2014 | 09:06 AM
Robosgood's Avatar
Robosgood
Default Abs
Hi have a 06 st150 ( re map ebiach springs induction straight through exhaust magnicore leads etc) my handbrake light n handbrake light came on got it diagnostic tested the guy said abs on rear changed that went back still happend. Changed my module my speedo came back and solved the problem. There £700 new without fitting! I got a 2nd hand one and fitted myself didn't take long a few bolts on the bracket and torx on the back and take the battery out. Good luck
original
Apr 28, 2026 05:20 PM
tomiii
12
Aug 18, 2015 08:40 PM
rdvil
Aug 15, 2015 12:11 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
