Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
Removing Air Con pipes from MK6 ST
Old Sep 21, 2013 | 12:36 PM
FiestaSTurbo's Avatar
FiestaSTurbo
Default Removing Air Con pipes from MK6 ST
Hi guys,
I am currently putting an ST engine in my fiesta but cant seem to get the air con pipes out from where the pipes go inside the car. Any help would be much appreciated.
Thanks,
Matt
Old Sep 21, 2013 | 04:17 PM
GVK.'s Avatar
GVK.
Put a pic up of the connectors.
Old Sep 24, 2013 | 09:19 AM
FiestaSTurbo
Heres a pic mate .
http://t.co/Bv0f7OkBQj
Old Sep 24, 2013 | 08:04 PM
GVK.'s Avatar
GVK.
See the white plastic ring on the left hand pipe, try sliding it under the connector (upwards from where it is now) it may release the spring.
If not you need to get the split plastic rings that are used to disconnect these fittings.
Struggling to find a pic of them on Google!
Old Sep 24, 2013 | 08:06 PM
GVK.'s Avatar
GVK.
Says fuel line on here but there are similar things for AC pipes, they clip round the pipe, then push up under the connector to spread the spring out which disconnects the fitting.
Old Sep 25, 2013 | 09:32 AM
FiestaSTurbo
Thankyou for your help mate, I will give it a try !
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
kevin36
Sep 2, 2015 06:24 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
