Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
Fan wont turn off
Old Aug 16, 2013 | 12:55 PM
Identical's Avatar
Identical
Default Fan wont turn off
The fan on my 07 zetec s wouldnt turn off after turning the engine off, i've checked the oil, water and the thermostat which are all fine. the only way i manage to get the fan off was by disconnecting my battery.
Can anybody tell me whats the problem and how to fix it?
Old Aug 16, 2013 | 01:01 PM
Brendan's Avatar
Brendan
struggling with reality
have you checked the water temp sender?
Old Aug 16, 2013 | 01:03 PM
Identical's Avatar
Identical
how do i do that? pretty limited mechanical skill
Old Aug 16, 2013 | 01:43 PM
adam151082's Avatar
adam151082
Sounds like its shorting out somewhere. Look for damaged wires.
Old Aug 16, 2013 | 01:44 PM
adam151082's Avatar
adam151082
Or try unpluging your fan switch and see if that works. Its a plug on your radiator.
Old Aug 16, 2013 | 04:54 PM
martysmartie's Avatar
martysmartie
On older cars, nowadays they are controlled via the ECU.
It may well be the relay has jammed, as I imagine when the ignition is switched off the fans should as well.
Do they start again when you reconnect the battery?
Martin
Old Aug 16, 2013 | 05:03 PM
I was about to say it might be controled by the ecu.
Old Aug 16, 2013 | 05:35 PM
Mr.T's Avatar
Mr.T
check the relais.
Old Aug 16, 2013 | 05:57 PM
GVK.'s Avatar
GVK.
It's the fan relay in the fusebox near the battery. Common fault.
Should tell you in the owners manual which it is.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
