Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Wheel offset question
Old Apr 9, 2013 | 06:55 PM
Rob H's Avatar
Rob H
Default Wheel offset question
Hi all,
New here and after some help.
Recently put some Puma wheels on my Fiesta as a friend was getting rid.
Looked at them and they have an offset of 34. Put them on and they seem to "stick out" more than other Fiesta alloys but they are still in the arches and do not rub or anything.
Well my question is will this lower offset do any long term damage/is dangerous.
There is some tyre hum from the front but I am taking that to be tread wear patterns (I put new tyres on the rear)
Any help would be great.
Old Apr 9, 2013 | 07:04 PM
STeve's Avatar
Super Moderator
its fine and if anything helps with handling as thats the perfect offset for the front and the rears could still come out another 12mm and be spot on
Old Apr 9, 2013 | 07:09 PM
Rob H's Avatar
Rob H
Great, thanks so much, been searching around the internet for ages and there is loads of conflicting advice about them hitting the arches etc. I have not gone wider or bigger in circumference or anything but some people say you should not go under 38 so was worried that I was 4mm under that!
Old Apr 9, 2013 | 07:45 PM
RichieST's Avatar
RichieST
Not true. You should stick as close to the standard offset as you can. Lower offset wheels will stick out more, put extra strain on the wheel bearings and will affect the handling, making it bump steer quite a bit more.
Old Apr 9, 2013 | 07:54 PM
Rob H's Avatar
Rob H
Brilliant, back to being confused!
Does that mean I will be chewing through bearings then?
Ok so I have 2 options, keep the Puma alloys which look better or take the wheels to a tyre fitter and swap off the new tyres that I bought from the alloys to the steels.
Each one is going to cost me money!!
Old Apr 9, 2013 | 08:04 PM
STeve's Avatar
Super Moderator
I get where richie is coming from but unless your running silly power or way oversized wheels I have found it improves handling a fair bit, I recently changed the wheels on my zs to lower offset but not going silly like french offset, I really enjoy the way it handles now
Old Apr 10, 2013 | 10:23 PM
Cosnada's Avatar
Cosnada
I thought the Puma was based on the Fiesta chassis - does it share suspension too? Not identical but it can't be too far off.
Old Apr 10, 2013 | 10:50 PM
denis's Avatar
denis
they are pretty much the same car under the body panels, lower offset wheels were used on the puma to fill the slightly larger arches
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
