Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk6 Fiesta Question.
Old Nov 27, 2012 | 10:31 AM
rstezza's Avatar
rstezza
Default Mk6 Fiesta Question.
Hi all, I have just bought an 05plate Fiesta Zetec S TDCI to use while I sort my Cosworth out. It’s the preface lift model. Now I’m told that the facelift model has one touch indicators? As in you press it once and it indicates 3 times? Do you know if this is true, also would I be able to fit this to mine?
I’m also lead to believe that the head lights from a facelift will bolt straight on, but the rear lights needs the plug changing? Is there anything else that would fit from the facelift?
Thanks in advance Terry. x
Old Nov 27, 2012 | 10:34 AM
JayCC's Avatar
JayCC
Everything you have written is correct.
Not sure about converting the one touch indicatiors though.
Old Nov 27, 2012 | 10:39 AM
rstezza's Avatar
rstezza
I would have thought it would just be a relay? Just like the windows? Hmm...
Old Nov 27, 2012 | 10:54 AM
RichieST's Avatar
RichieST
On the mondeos you need to change the GEM module to get the one touch indicators to work, I presume it is the same with the fiesta!
Old Nov 27, 2012 | 11:27 AM
rstezza's Avatar
rstezza
Ive just had a quick look on ebay the GEM module seems to point to the GEM MODULE REMOTE CENTRAL LOCKING UNIT or are there more than one?
Old Nov 27, 2012 | 11:32 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I thought the facelift was mid 2004?
Old Nov 27, 2012 | 11:40 AM
rstezza's Avatar
rstezza
55plate im lead to belive,
Old Nov 27, 2012 | 11:41 AM
RichieST's Avatar
RichieST
The GEM controls the central locking, interior light delay, wiper intermittent delay, indicators, hazard lights etc. Basically anything on the car that requires timing or a sequence to be followed etc is done by the GEM.
Old Nov 27, 2012 | 11:47 AM
seaNNN's Avatar
seaNNN
everything you have written is correct tezza including the one touch indicators im going to guess that you can't retrofit it to the mk6 easily but then again I know nothing
Old Nov 27, 2012 | 01:09 PM
rstezza's Avatar
rstezza
Would this not mean id need to have my key resync? Or dose this just control the lights when i lock it? Sorry if it seems a silly question.
Old Nov 27, 2012 | 01:13 PM
RichieST's Avatar
RichieST
It will still work to start the car but if you have remote locking then you will need to re-program it. It is quite easy though the procedure should be in the owners manual.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
