Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Grinding pistons
Old May 17, 2012 | 10:46 PM
harleyfish's Avatar
harleyfish
mk3 with racing 1300 kent
Lightbulb Grinding pistons
Am i mad people?
i have a 1.3 kent with a racing head so the inlet valves 41.5 mm and the exhaust is 32mm
The pistons are escort 1.1 to raise compresssion
the valves are catching slightly on the edges of the pistons
can i grind out the pistons slightly so they clear with a dremmel or something
make sure they all weigh the same and file off any sharp areas?
would this work?
Old May 17, 2012 | 10:47 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
technically yes, it just wont look pretty. as long as you dont go too deep, you should be fine. i've heard of people using angle grinders before
Old May 17, 2012 | 10:50 PM
harleyfish's Avatar
harleyfish
Default wow
that was fast
they only catch slightly so its not mass removal.
Any 1 know a place to get 1.1 escort piston rings as i broke 1 being heavy handed?
Old May 17, 2012 | 10:51 PM
harleyfish's Avatar
harleyfish
thanks md cos
Old May 17, 2012 | 11:03 PM
botters's Avatar
botters
competant bodger
grinding them is a bit pikey but doable you should really get valve cutouts done at a proper machine shop
Old May 17, 2012 | 11:24 PM
harleyfish's Avatar
harleyfish
i am a bit of pikey anyways
Nov 1, 2015 06:53 PM
20/20 vision
Sep 29, 2015 09:25 PM
deathrider666
Sep 28, 2015 06:12 PM
ajamesc
Sep 8, 2015 06:51 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
