Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk3 Fiesta electrical problem
Old Oct 19, 2011 | 06:42 PM
roj's Avatar
roj
Default Mk3 Fiesta electrical problem
Hi all, I need some urgent help with my mk 3 Fiesta if anyone can help....
I Have been having problems starting, appearing to be a discharged battery.
I have fully charged battery off car. Still turns over a bit sluggish but starts.
Battery tests out OK. Charging from alternator checks out OK.
However...
When I switch the lights on, whether side, dip or main the main beam warning light is on and there is a loud buzzing noise from somewhere in the dash area!
Main beam warning light goes off and buzzing stoops when lights switched off.
Any help appreciated, Thank you )
Old Oct 19, 2011 | 07:16 PM
RichieST's Avatar
RichieST
Is it an electrical buzz or a buzzer like the door open when lights on buzzer? I'd be checking all the earth points first, especially engine to chassis.
Old Oct 19, 2011 | 07:24 PM
roj's Avatar
roj
It's definately a low level buzzer sound not an "electrical buzz". It appears to be coming from the lower part of the instrument clustewr in the dash.
Problem only started today when about to go out after dark
Old Oct 19, 2011 | 07:41 PM
roj's Avatar
roj
Default Sorted! operator error, lol!
Thank you!
Following your post I double checked the battery connections, and found I had missed a small lead off the negative terminal when replacing the battery after recharging (during the day) - it had fallen down behind the wiring!
Result - Main beam warning light now out when lights on, ( unless on main beam on of course ) and no buzzer sound coming from the dash!
andyrs1600i
Apr 29, 2026 03:21 PM
23
Sep 12, 2015 12:56 PM
Ben26
Aug 27, 2015 08:56 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Bosch
Aug 4, 2015 05:14 PM
