Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Replace Clutch - £500
Old Jul 28, 2011 | 11:24 AM
AMO's Avatar
AMO
Default Replace Clutch - £500
Hi there,
I have a Ford Fiesta Ghia 03 plate.
I have been quoted £500 (negotiated down from £600) to get a clutch replacement at a local dealer.
Is this a reasonable cost?
Thanks
AMO
Old Jul 30, 2011 | 03:05 AM
AMO's Avatar
AMO
Ok, I got this diagnosis from a Ford Dealer:
Costs (inc VAT)
Clutch Replacement £643.06
Gear Box Torque Restricter £51.11 (do with clutch - no added labour charge)
Discs Front Worn change with pads £216.00
Nearside Headlamp motor running all the time head lamps are on
Front indicator bulbs starting to discolour
£45.53 (both)
Total: £955.70
However, I asked for a quote based on the above in red, and I got this from a local:
Labour
Clutch - assy Remove & Refit 199.80
Flywheel/drive plate Remove & Refit 10.80
Parts
*621301133 3 part clutch 1.00 189.99 189.99
*415018210 Single mass flywheel 1.00 319.99 319.99
So one will change the Gear Box Torque Restricter and another will change the Single Mass Flywheel.
I assume they are different components right?
Thanks,
AMO
Old Jul 31, 2011 | 04:36 PM
Churtz's Avatar
Churtz
Yes they are different parts. I'm not sure why anyone would quote for a flywheel (solid) without inspection I.e with the box removed.
And I've never changed a torque restrictor on these and never had problems.
Matt
Old Jul 31, 2011 | 05:25 PM
AMO's Avatar
AMO
Thanks Matt. I appreciate the response.
Basically, my wife's car judders in 1st gear when you accelerate through it.
The Ford Dealer came to the conclusion that the clutch needed changing and also the torque restricter.
What's your view on that symptom?
The car has done about 35,000 miles since new.
Old Aug 1, 2011 | 01:16 PM
R4N SS's Avatar
R4N SS
you need to get it apart to find out what it really needs mate
Old Aug 1, 2011 | 02:48 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Get another garage do give you a quote ford are expensive,i bet you could get it done for £300
Old Aug 2, 2011 | 07:16 PM
AMO's Avatar
AMO
Thanks all.
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
Vacuman
Sep 22, 2015 12:09 PM
Flateric_2002
Sep 15, 2015 08:41 AM
NC53
Sep 13, 2015 03:05 PM
