Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
2003 Fiesta Mk6 Passenger Electric Window Problem - does not work
Old Mar 16, 2011 | 12:17 PM
dickybow's Avatar
dickybow
Default 2003 Fiesta Mk6 Passenger Electric Window Problem - does not work
Hi
This week I picked up a 2003 Fiesta Mk6 from an auction.
Neither electric windows worked, except the drivers after I removed and refited the electrical block in the door shut and after I punched the door following advise I saw elsewhere on the internet!!
Still the passengers window does not work. Despite doing the above.
Now, the passengers window switch on the drivers side does nothing.
But on the passengers side, pressing 'UP' you can here a faint click like you'd usually get BUT nothing when you press 'DOWN'.
Could anyone please help ?
Any advise would be gratefully received.
Thanks !
Old Mar 16, 2011 | 03:14 PM
dickybow's Avatar
dickybow
Ok, just taken the door apart, the motor is definitely getting its 12v when you press 'UP' but only 2v when you press 'DOWN' ??
Old Mar 16, 2011 | 05:25 PM
JonathanJ's Avatar
JonathanJ
had problems with the switches on these , see if you are getting just the 2 volts out from switch end , if so it will most probably be switch
Old Mar 16, 2011 | 05:38 PM
nthorpey's Avatar
nthorpey
as above switches are dodgy as are the plastic drive gears on the end of the motor
Old Mar 21, 2011 | 09:27 AM
dickybow's Avatar
dickybow
Hi,
I recieved a new switch from ebay this morning, and to my disappointment it hasn't worked.
Shall I now try a new motor ?
Old Mar 21, 2011 | 10:02 AM
martysmartie's Avatar
martysmartie
I doubt it's the motor, it sounds more like a jam perhaps, have you tried lubeing the runners etc, seeing if the windows jammed?
Martin
Old Mar 21, 2011 | 10:25 AM
JonathanJ's Avatar
JonathanJ
Where abouts in Birmingham are you ? See my location
Old Mar 21, 2011 | 02:01 PM
dickybow's Avatar
dickybow
Hall Green mate
I'm going to google how to have a peek at the runners. Fingers crossed I don't break the glass !
Old Mar 21, 2011 | 03:27 PM
nthorpey's Avatar
nthorpey
when you press the button do you hear the motor turn?
if so plastic gear is broken as there is no clutch and stiff rubbers can cause this.
if it's not turning lub the rubbers and check again, if it still isn't working you need to access the motor to see if there is voltage there when you operate the switch to diagnose.
Old Mar 21, 2011 | 09:57 PM
dickybow's Avatar
dickybow
Like I said the motor is definitely getting its 12v when you press 'UP' but only 2v when you press 'DOWN' ?
2v when pressing 'DOWN' - Is this normal ?
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
