Rs turbo re shell into mk3.5 help
Old 08-05-2014, 08:10 AM
myoldfiesta
myoldfiesta's Avatar
Default Rs turbo re shell into mk3.5 help
Well, my rs is dead, too much welding needed and too many previously bodged repairs have put an end to her unfortunately,
However I am going to re shell her, iv picked up a nice clean mk3.5 1.1,
All I have is a couple of questions,
Interior wiring loom, do I need to rip it all put and fit the rs wiring instead?
Front suspension, anti roll bar ect, is the anti roll bar stronger on the rs than on a lower model? If so do I change the whole front subframe over or bolt the rs bar to the standard 3.5, then the lower arms, can I bolt my rs stuff into the 3.5 subframe?
Fuel tank, swap it out for the rs item?
Many thanks in advance
Luke
Old 08-05-2014, 01:43 PM
Steve the Plumber
The original Rouge Trader
Steve the Plumber's Avatar
What's a mark 3.5 escort?
Old 08-05-2014, 01:56 PM
Acidburn
Acidburn's Avatar
he's on about a fiesta
Old 08-05-2014, 02:22 PM
fiesta23
fiesta23's Avatar
The front suspension is different on the 3.5. The hubs are different in diameter where the shocks go. might be wrong but the lower spec 3.5 didt have the anti roll bar. I would change the whole front suspension.
With regards to the wiring I would keep the wiring the same apart from the engine loom which will be different.
Craig
Old 08-05-2014, 02:24 PM
fiesta23
fiesta23's Avatar
The fiesta has an in tank fuel pump so would be best changing the fuel tank and I think its different on the rs, unless your putting an uprared one in, or a new one. If so I would pick the best one of them.
Old 08-05-2014, 03:33 PM
Steve the Plumber
Ah ha! That will explain why I haven't heard of one! I must be getting old!!
Old 22-05-2014, 08:35 PM
myoldfiesta
Ok cheers guys,
Iv swapped all the suspension and hubs, including anti roll bar, that's all good yo go,
Just trying to sort an engine now
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
Gary @ RS CLASSICS
11
10-09-2015 06:49 AM
JPA
01-09-2015 09:12 PM
Quick Reply: Rs turbo re shell into mk3.5 help
