Speed sensor needed
Old Feb 10, 2005 | 08:40 AM
Dilithium's Avatar
Dilithium
Default Speed sensor needed
Good morning people,
I'm guessing a bit here but, here goes: -
I've spent last night finding and labelling all the connections on my Fiesta RST engine loom to go into my Westfield with a type-9 gearbox. However, I'm missing a speed sensor that connected to the RST FWD gearbox.
I'm guessing that the Sierra used a 1.8 CVH and type 9 and was rear wheel drive, using the same EFI managment as the FRST.
What/where would I find one, please (new or used) ?
I suppose the engine would fire up using the Crank Position Sensor (which I have) but, wouldn't actually go anywhere without the info from the Speed Sensor. Any help in acquiring one for a type-9 (or an alternative resolution to the problem) would be very much appreciated.
Thanks,
Neil
Old Feb 10, 2005 | 04:07 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
ive got 1 in the shed some where
there very expensive new from ford
Old Feb 12, 2005 | 02:50 PM
Low Down And Dirty's Avatar
Low Down And Dirty
Try EBAY mate I'm sure I saw one on there today when I waz lookin through.
Old Feb 13, 2005 | 11:32 AM
sammy's Avatar
sammy
it will run fine without it, its there to hold the revs slightly assisting gearchange
Old Feb 13, 2005 | 02:51 PM
Dilithium's Avatar
Dilithium
Cheers, Sammy,
Thanks for confirming. I phoned Motorsport Developments. (Someone told me they run/host this site). The guy said the same thing... that it'll hold the revs at 1100 rpm whilst the car is in motion, dropping it back to it's normal idle at around 900 rpm once the car comes to a stop. I'm feeling a bit more relaxed now
Do you know what it reads? Is it actual road speed or is it just telling the ECU that the car is still in motion?
My speedo is digital and measured from magnetic pulses from rear differential's bolts. If it's only cheking for movement I was thinking I could use the output of the speedo to the VSS on the loom.
Thanks again,
Neil
Old Feb 13, 2005 | 05:19 PM
sammy's Avatar
sammy
im not to sure how it actually works, but when i had the ofab system on mine, the sensor was disconected & it seemed to run fine. ive got digital dials (gte) in mine
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
col93saphcos
Aug 7, 2015 03:21 PM
