t3 parts help??
t3 parts help??
hi all, need some parts for my t3 conversion.
Can any1 help where to get them from other than the obvious answer FORD dealers.
I need four nuts to bolt the turbo to the manifold
A full turbo gasket set
8 studs and 8 bolts to bolt the manifold into the block.
Thanks in advance
Matt
Thanks in advance
Matt
trevor at www.fordpartsuk.com he will sort you out with everything you need as the main dealers have stopped some of the items you need, ask him for the oil retun plug for the block as ford dealers do stock this part.
Chris.
Chris.
07-10-2015 12:56 PM
