EFI idle probs
EFI idle probs
Got efi in my s2
If i blip the throttle it doesnt return to idle right away, revs for afew secs then returns
if i disconnect the iscv, after a blip it returns to idle as it should do
also the idle is at 500rpm
any ideas?
Car is standard
any ideas?
Car is standard
try the idle speed control valve, it should be located on the side of where it says efi on the inlet manifold a cylindrical little unit should be mounted there i think. you can give it a clean or a new one, i suggest try cleaning it. its a possibility.
