xr help
Is there anyone that can recommend me any good mechanics in the middlesex area?
As apparently the reason why my car will not start is because of an electrical problem.
Please let me know if you can help.
if its electrical check spark plugs leads dizzy cap rotor arm and contact breaker points oh and the condensor.
oooooooooooh not to sure if the XR has it aswell hand on mk1/2?
IF it's an XR2i check for spark and fuel if you are getting neither change the CPS (Crank Position Sensor as these can go down with little or no warning
fanks it was the crank sensor jus covered up in grease cleaned it up an it stars 1once again im amazed tho how that was the problem cheers oranoco
