How do i stop........
Old Aug 12, 2006 | 03:47 PM
Phil DJ's Avatar
Phil DJ
Default How do i stop........
My passenger front wheel from rubbing the inner arch when i go to almost full lock.
It's not just rubbing slightly, it's torn the plastic and the paint from the bodywork behind. Any way i can stop this? Tried 4mm spacers but it still done it. Any further and my wheels will be sticking out of the arches
Old Aug 12, 2006 | 08:36 PM
foreigneRS's Avatar
foreigneRS
Testing the future
put some jubilee clips on the ends of the steering rack to stop it turning too far
Old Aug 13, 2006 | 09:35 AM
Phil DJ's Avatar
Phil DJ
Problem is tho, it happens before full lock.
For instance, if i need to do a U-turn
Thanx for the suggestion tho, will keep it in mind
Old Aug 13, 2006 | 09:47 AM
fiestaturbo1984's Avatar
fiestaturbo1984
are your wheels the right offse? and what tyres you running?
Old Aug 13, 2006 | 01:59 PM
Phil DJ's Avatar
Phil DJ
My wheels are et35 and I'm running 195/50/15
Old Aug 14, 2006 | 12:44 AM
jayRS's Avatar
jayRS
the rack prob aint central.
if it is, then its prob the wrong rack (as FRST had its own rack)
or the wheels are to blaim.
i had it years ago and it was cos i got given the wrong rack when i replaced it
Old Aug 14, 2006 | 11:58 AM
Phil DJ's Avatar
Phil DJ
I know it didn't with the standard rims. As far as i know, the rack is the original XR2i one
Old Aug 14, 2006 | 12:15 PM
jayRS's Avatar
jayRS
xr2i ones are same as other fiestas, its only frst that has different rack as its a quick rack and has a lock to lock of 3.75, where as the xr2i etc has a 4.25 lock to lock, thats another halh a turn
Old Aug 14, 2006 | 04:27 PM
Phil DJ's Avatar
Phil DJ
Ok, is there any visible differences between the 2 so i can see if it's correct?
Old Aug 14, 2006 | 04:34 PM
ben_frst's Avatar
ben_frst
the problem is you running 195/50/15s you need a 45 profile, the rack makes no differance altho the frst rack is a different ratio the car still has the same turning circle
Old Aug 14, 2006 | 04:46 PM
Phil DJ's Avatar
Phil DJ
There is that i guess. But i reckon it would still rub with 45's on coz it's catching quite heavily and that's just before it reaches full lock
Old Aug 14, 2006 | 04:49 PM
Brookesy's Avatar
Brookesy
Try getting all the tracking, castor & camber checked
Old Aug 14, 2006 | 05:24 PM
jayRS's Avatar
jayRS
50 profile dont mean jack, i had 50's once as i needed tyres asap and thats all they had, and they rubbed, but then even with the 45's before and after it still rubbed.
you can get limiters for the rack, or used to be able to.
your problem if its not the rack etc, will be due to wheel size, if you have 6.5x15's your ok, if you got 7x15's it will rub, but off set comes into this as well.
Old Aug 14, 2006 | 05:29 PM
jayRS's Avatar
jayRS
to check the lock to lock, turn it full lock 1 way, say to the right, then count the numberof full turns the steering wheel makes plus any 1/2's or 1/4's and that will tell you what lock to lock you got, from there you can work out what ya got.
Old Aug 14, 2006 | 06:59 PM
Phil DJ's Avatar
Phil DJ
I'll check the width of the wheels then. Am i right in saying that et35 offset is probably the wrong offset aswell?
Old Aug 14, 2006 | 07:18 PM
jayRS's Avatar
jayRS
tbh mate off the top of my head i cant remember what the standard offset of the fez is
Old Aug 14, 2006 | 08:34 PM
Phil DJ's Avatar
Phil DJ
Doh!
Old Aug 14, 2006 | 11:38 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Standard offset is ET37 i believe.
Im runnig 7x15" Alloys with 45 profiles and i get VERY slight rubbing on full lock - this is with an offset of ET35. The alloys are ET40, but they rubbed badly on the shocks so im using 5mm spacers.
HTH
Im ordering a set of 6.5x15 ET37 alloys soon - wil be interested to see if they rub or not - i doubt they will with an extra 2mill of clearance and half and inch less width.
Old Aug 14, 2006 | 11:45 PM
jayRS's Avatar
jayRS
the the higher the number e.g et40 the closer to the shock the wheel is, or another way of looking at it, the further away the center is.
that about right?
Old Aug 15, 2006 | 12:18 AM
AGAR-COSWORTH
Redumbdancy
jayRS - correct - hence why ET40 rims caught on the inside against the shock, then with 5mm spacers (making them ET35 offset) they didn't rub - ie further away from the suspension.
Old Aug 15, 2006 | 12:36 AM
jayRS's Avatar
jayRS
sweet, i got some mondeo rims to go on my fez that are ET40, i got coil overs so thats not a prob, well fronts "might" need a small spacer to clear the ARB drop link bolt as the 15s touched it, well did untill i file 4 mm off the end of it
yeah thats good, cheers for that mate, hopefully the rear will be ok now as with the rear disc conversion it pushed the wheel out about 20mm and the wheel started to catch the arch a bit
Old Aug 15, 2006 | 04:46 PM
Phil DJ's Avatar
Phil DJ
But mine are ET35 and they rub like fook on full lock???
Old Aug 15, 2006 | 05:41 PM
jayRS's Avatar
jayRS
get some restrictors and fit them in the rack, ford might still sell them
Old Aug 15, 2006 | 08:08 PM
AGAR-COSWORTH
Redumbdancy
Also depends on width of the rims you have.
Old Aug 15, 2006 | 08:24 PM
Phil DJ's Avatar
Phil DJ
Fuck it, i'm gonna put the standard ones back on for now i think
Old Aug 16, 2006 | 12:09 AM
jayRS's Avatar
jayRS
dont give up so easy mate, how wide are ya rims?
Old Aug 16, 2006 | 04:36 PM
Phil DJ's Avatar
Phil DJ
Just got the tape measure out coz i couldn't be asked taking a wheel off to look behind it.
8" wide
Think i've found my problem
Old Aug 16, 2006 | 06:36 PM
AGAR-COSWORTH
Redumbdancy
Bingo
Atleast you've got to the bottom of it. 8 inch wide is Escy Cos territory
Old Aug 16, 2006 | 06:39 PM
Phil DJ's Avatar
Phil DJ
I don't know. They don't look as wide as escos rims. Maybe i measured them wrong or something.
I know the guy i bought them off had them on a MK3 Escort Cabriolet and he had no problems
Old Aug 16, 2006 | 07:12 PM
Phil DJ's Avatar
Phil DJ
Ok, i took a wheel off and behind it was stamped "7.0xJ15" which is weird coz it's definately 8" wide
Double checked on my standard wheels and it's got "5.5xJ13" and i measured that at 5.5" wide
So is the stamp on my 15" wheel wrong then?
Old Aug 16, 2006 | 09:04 PM
jayRS's Avatar
jayRS
na prob not, did you allow for the tyre?
thers ya problem mate, 7 inch wide, same as me, and same problem.
all ya can really do is make sure the rack is central and when the tracking done there isnt loads of adjustment on that side.
oh and hope for the best
it is a tiny bit possable that a small wheel space will help it (not stop it, and fit 1 to each side)
Old Aug 16, 2006 | 09:36 PM
Phil DJ's Avatar
Phil DJ
The wheel is the same width as the tyre. Took the wheel off and measured from the inner rim to the outer rim. 8".
Sold them to my bro now anyway. He has my old XR2 and they fit on there no probs
Old Aug 16, 2006 | 10:26 PM
jayRS's Avatar
jayRS
fair play then mate, problem solved
Old Aug 17, 2006 | 04:32 PM
Phil DJ's Avatar
Phil DJ
Change of plan. In a last ditch attempt, i'm gonna try 6mm spacers and trim the plasctic arches right back
Old Aug 17, 2006 | 08:48 PM
jayRS's Avatar
jayRS
Old Aug 18, 2006 | 05:56 PM
Phil DJ's Avatar
Phil DJ
Didn't work. Standard rims back on. Think i'll save up for some Mondeo 16's now
Old Aug 18, 2006 | 07:01 PM
jayRS's Avatar
jayRS
Old Aug 19, 2006 | 09:18 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i've got some for sale, the 4 spoke 'turbo' design in 7.5". had them on my mk1 escort
Old Aug 19, 2006 | 11:34 PM
Phil DJ's Avatar
Phil DJ
What do they look like? Any pics?
