XR2i Wheel Offset
Jep, that explains it all.
Because if wheels have the same width, but the ET is different , the wheel will go to, or away from the inner arch.
for example: wheel 1 = ET 30
wheel 2 = ET 35
wheel 2 go's 5 cm more to the inner arch. Or to the rear dampers
In definition ET is the clearens (in cm) between the centerline of the tire and the plate of the wheel that go's against the wheel hub. In possitive or negative direction.
Greetz
(sorry for my bad englisch)
wheel 2 = ET 35
Greetz
Adam Graham
06-09-2015 06:04 AM
