Si problems.......Can u Help????
Old Aug 3, 2004 | 05:29 PM
scuddSi's Avatar
scuddSi
Default Si problems.......Can u Help????
Old Aug 3, 2004 | 05:53 PM
scuddSi's Avatar
scuddSi
right, over the last few days iv had a leaky radiator pipe which is located at the front left of the engine bay , sort of above the cam belt.
the car now all of a sudden wont start and needs a jump start to get things going.
- me stereo isnt wokin either
- on one occasion the rev counter was jumping with the indicator
- the car wont rev above 1500 revs
so basically me car is pretty fcuked ....... not good when ur about to convert to a 2.0L
Can any1 shed any light on the situation.....any help would be appreciated .
thanx people
****** This is what should of been on the post ******
Old Aug 5, 2004 | 03:03 PM
scuddSi's Avatar
scuddSi
come on people i need ur help here
Old Aug 26, 2004 | 09:09 AM
cherb1's Avatar
cherb1
has your car had any kind of superchip fitted???
I had the same kind of problem with my si.
The car had been fitted with a powerchip!
The car showed the same kind of problems you are talking about.
I took the car to ford and they could not find any fault!
It wasn't until i took my car to a Local Autoelectician that the found the fault.
They removed the chip from the ECU and replaced it with the standard factory one.
All the problems that i were having cleared instantly!!!!
Hope this is of some help to you.
cherb
