Fiesta RST
Hi guys just bought a FRST and im new to um and it feels really quick it has a dump valve, a lil brass screw thing on boost piep sum1 sed a boost controller and a ind kit!! it feels really quick so wanted to kno if u lot cud tell me how i could find out wots bin dun to it as i dont kno itz history
thanks
thanks
why dont you take some photos of the engine bay and post them up,that way we can see the obvious bits? you can easily check to see if its chipped,look under the passengers side dashboard and you will see the ecu,if theres a little cartdidge plugged into it (looks like a megadrive game usually lol) then thatl be a superchip or similar. you can also check the fuel injectors,blue is standard,beige are uprated.
hope this helps
ps.please try to spell correctly and not like a chav
it makes it a pain to read
hope this helps
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Originally Posted by markfrst2006
how do u check injectors?? where do i look??? and yes it does look exactly same as that some1 told me it was a manual boost controller thanks for help guys
can i just ask whats so bad about having a bleed valve?reason im asking is cos i took my car 2 interpro for chip and full dyno and they told me i needed a bleed valve and put 1 on and took away my amal valve,is this right?they also charged alot of £ too!
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
mines has bin checked out and it has bin turned down itz not a bleed valve but a manual boost controller so mines ok they sed if it was turned up then it wud b quicker ie more boost but be too lean and go bang
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
I've got a manual boost controller on mine! had to turn mine down a touch after my last trip to powers as it needs setting up again and was running a bit lean, guess where it is going again after my new bigger brakes are on....
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Originally Posted by Scottish Greg
Nothing wrong with bleed valves as long as you leave them alone. Had one on mine for 50k miles with NO problems ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
I had a bleed valve on mine, but its pointless as when u turn it up over 10psi the ecu sets into over boost and when u get into higher gears i.e high revs 4th & 5th it keeps shutting down and jerking! so it really isnt no good unless its chipped.
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
