Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
MK4 Escort EFI ECC IV system.
Old Oct 20, 2022 | 09:15 AM
koopza21's Avatar
koopza21
89 Xr3i
Default MK4 Escort EFI ECC IV system.
Hi Guys,
Does anyone have a picture of efi engine management system wiring diagram? For some reason the Haynes doesn't show the EfI system.
I have a cooked ECT coolant temp sensor, but the feed in at plug is 12v were I'm thinking it should be 5v, it was rebuilt by someone, so I wonder what has possibly been wired in.
Old Oct 21, 2022 | 06:24 AM
XR2's Avatar
XR2
I'm not sure about the coolant temp sensor but the early EFI systems are a pain in the a*** as the sensors (I'm sure about the MAP) don't work with a voltage signal but with a frequency signal. So 12V MIGHT be ok but keep in mind testing sensors like the MAP won't work with a simple resistance test.
Old Oct 21, 2022 | 07:36 AM
koopza21's Avatar
koopza21
89 Xr3i
Cheers bro, I have to clarify I was on the cooling fan switch on thermo housing which looks like ect (I'm Australian ha) . I have 5v at ect under inlet manifold ect and confirmed ect sensor is open circuit. Would love a MK4 escort Ecu diagram found a sierra which looks similar. Down the track I will replace Ecu to a haltech. Try and rip as much as I can from a n/a xr3i. Turbo is the easy way, I'm think original but tuned hard will suffice. Will update how ect replacement goes.
Old Oct 21, 2022 | 07:39 AM
koopza21's Avatar
koopza21
89 Xr3i
I'm also stunned at the price of 3 pin Bosch connectors 45 bucks. As an auto electrician 20yrs back these were like 10 bucks, inflation a.
steve.rst
Aug 15, 2014 07:52 PM
Toe Knee
Sep 9, 2009 03:05 PM
Toe Knee
May 5, 2009 01:57 PM
Dan16v
Aug 27, 2008 04:41 AM
