Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Aftermarket Header Tank
Old Aug 4, 2022 | 03:01 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Aftermarket Header Tank
As above really, anyone know of a supplier of these for a EFI XR3i(tank on passenger side).
cheers.
Old Aug 4, 2022 | 06:06 PM
XR2's Avatar
XR2
Isn't it possible to use one of a non-EFI model? It seems to me the hose connectors are in the same place?
Mounting points could be different but this just means drilling two small holes into the inner wing.
Old Aug 4, 2022 | 06:56 PM
XR2's Avatar
XR2
After checking the Ford parts catalogue and asking a friend of mine who has owned a lot of MK4 and has an EFI one right now I know a little more.
The inner wings and therefore the header tanks were modified 1989 when the EFI CVH was introduced. The non-EFI header tanks (sitting on the drivers side) won't fit the pre-89 cars/shells as these tanks are higher. Funny thing is the EFI header tanks had the same shape as the pre-89 tanks (the ones mounted to the right / UK drivers side). Only difference is the position of the hose connectors. These sit slightly to the left or the right side but the hoses should be long enough.
Old Aug 4, 2022 | 09:18 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Cheers some good info there,Im thinking one of these would fit, maybe have to drill some holes to mount.
https://www.autospecialists.co.uk/pr...s-turbo-s1-s2/
Old Aug 5, 2022 | 04:20 AM
XR2's Avatar
XR2
Fingers crossed drilling new mounting holes is all you need!
cossiemanden
Aug 31, 2007 08:58 PM
cheekynige
Mar 18, 2007 10:19 AM
Paul
Oct 17, 2004 02:25 PM
