Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Starter motor engaging issue
Old May 8, 2016 | 05:26 PM
Shaunc's Avatar
Shaunc
Default Starter motor engaging issue
Wondering if anyone can give me some help on a suspected wiring issue on my 89 MFI xr3i. The car won't start after putting some parts back in the engine bay I took out for spraying (inlet manifold, throttle body, WUR and rocker cover). All plugs were labeled and definitely put back in the right place.
Problem I have is that the starter motor won't engage. I have tested the starter motor off the car and it works fine. I have tested the permanent live to the starter and I am getting a reading on my multimeter but when testing the ignition live terminal on the starter (the covered push on fitting) I am getting no reading on the multimeter.
Can anyone shed any light on the problem before I start ripping wiring loom to bits??!!
Old May 8, 2016 | 05:36 PM
haz87's Avatar
haz87
The excitor wire (red/black trace iirc) usually breaks further down the line (around the reverse sender type area of that piece of loom).
Old May 8, 2016 | 06:03 PM
Shaunc's Avatar
Shaunc
What do you mean by excitor wire mate? Did you mean ignition? And where in the engine bay should I be looking?
Old Jun 9, 2016 | 05:14 PM
Shaunc's Avatar
Shaunc
So turns out it was the ignition switch! Swapped it for a new puma one. Puma escort and fiesta mk4/mk5 are all the same
AVR2
Mar 21, 2016 12:52 PM
Acaciastrain360
Mar 15, 2016 04:02 PM
2Litre
Mar 14, 2016 09:57 AM
Mk3Ghia
Ford Focus ST
Mar 12, 2016 04:43 PM
Paul_RS
Mar 7, 2016 07:43 PM
