Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Mk4 Escort (battery/alternator?) help needed!
Old Nov 2, 2015 | 01:34 PM
anthony lea's Avatar
anthony lea
Ford allegiance
Default Mk4 Escort (battery/alternator?) help needed!
Hi all,
My Escorts battery light started to glow on the instrument panel a few weeks back and the volts (LCD meter I fitted to the dash) was showing it was steadily dropping to 11-12v at first to eventually less than 10v (the day after the battery was actually flat). I noticed the night before whilst driving that the volts would rise and the battery light dim as you accelerated. I assumed the battery wasn't holding charge and bought a new one. I have fitted this and the battery light is still on but dims as you accelerate but the voltage is still around 11-12v which is more like 11v with heaters and lights on etc. I know it should be more like 14v...
Would I be right in thinking that it is probably an alternator fault?
What is the easiest way of diagnosing if it is?
Cheers for any input,
Anthony.
Old Nov 2, 2015 | 03:39 PM
RichieST's Avatar
RichieST
Certainly sounds like the alternator. Check the belt hasn't broken/come off and also check the thin blue wire that comes off if the alternator for corrosion etc. If the blue wire isn't making a good contact the alternator will not charge.
Old Nov 3, 2015 | 06:01 PM
Marty123's Avatar
Marty123
I had the same problem a few years ago with my mk4, it turned out to be the alternator, after fitting a new one I've had no further problems. Ps the alternator I replaced was only 18 months old.
52
Nov 21, 2019 04:16 PM
cossie09
12
Dec 6, 2015 07:18 PM
Quaver
Nov 3, 2015 01:32 PM
Brocker
Nov 2, 2015 01:01 PM
Krj
Oct 28, 2015 11:14 PM
