Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Xr3i starting problem (ish)
Old Sep 22, 2015 | 05:53 PM
Shaunc's Avatar
Shaunc
Default Xr3i starting problem (ish)
OK....
So Im finally getting there with my 89 XR3i MFI (k jetronic), its now starting (sort of) and running great! However there is this small problem of the car not quite starting first time every time. It usually only starts after about 3 turns of the key but will start straight away no problem when is has been run for a while.
It only had to be run for about 5-10 min then it will start easy for up to half an hour.
When "cold" starting it will turn over then start first time then die a few seconds later and this will happen about 2 to 3 times before finally running. When it is running it runs like a dream, idling correctly etc.
So far I have:
Changed fuel metering unit
Had fuel mixture and idle set
Changed fuel tank and ran 2 tanks of fuel with a cleaner
Changed starter motor
Cleaned all intake and breather pipes
Cleaned and refurbed throttle body
Done full service
Changed dizzy cap and rotary arm
Changed ht leads
New fuel pump
I have also checked for any vaccum leaks (because that was causing my main issues before and it was the sevo pipe) using the carb cleaner technique and the only place that brings up any results is the fuel mixture screw hole which is alllways open anyway.
I have been pointed towards the warm up regulator for obvious reasons and the fuel accumulator which I have been told sets and maintains fuel pressure.
Would anyone be able to give me definite answer to this problem, or as near to definite as can be before I go shelling out for a new accumulator or warm up reg?!
Old Sep 22, 2015 | 06:08 PM
haz87's Avatar
haz87
Before even looking at your list I was going to say WUR.
Rather than just keep buying new bits why not just measure the fuel pressure and check if it is or isn't within spec?
New WUR's arent cheap!
Old Sep 22, 2015 | 06:10 PM
haz87's Avatar
haz87
Oh and it could also be the non-return valve in the fuel pump - again monitoring fuel pressure and residual pressure will show this as faulty.
Its far cheaper and stress free to take the diagnostic approach with K-Jet than just replace bits.
Old Sep 22, 2015 | 06:44 PM
Shaunc's Avatar
Shaunc
Thanks for the help mate. I rwplaced most parts because the xar was stood for 5 years before i bought it and it was abit of prevention to what could go wrong but i think most of my problems were from the fuel metering unit affecting the mixture.
Will the fuel pressure give me the answer I need?
Also what is the best way to test fuel pressure? I have never done that before
Old Sep 23, 2015 | 06:00 AM
Shaunc's Avatar
Shaunc
Well think i have answered my own question haha
Just been watching videos on testing fuel pressure on k jetronic system so I'm gonna buy myself a kit and see how I go on!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dahl88
Aug 22, 2015 08:16 PM
stevierob
Aug 11, 2015 09:08 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
