Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Setting RS1600i
Old Jul 14, 2005 | 02:25 PM
Martein's Avatar
Martein
Default Setting RS1600i
Hi !
I got an RS1600i, but it runs pretty bad.
On idle it's running fine (CO and HC value are OK)
but when reving it, the HC value increases (unburnt fuel)
I've modified the airhose which goes between the meteringhead and the throttlevalve (it's slightly bigger diameter and a bit shorter... does this affect the working of the K-jetronic ?)
So it's overfuelling OR getting to little air.
anybody knows what I can do to adjust this ??? Or know what books I need to get to get it set up properly. ?
Thanks.
Martein
Old Jul 27, 2005 | 09:53 AM
Scott R's Avatar
Scott R
I would say at a guess your fuel pressures could be wrong.
If you have access to a fuel pressure guage, connect it between the feed from the metering head to the warm up regulator, get the car warm, ( by running it for a short time), then bridge your fuel pump relay so that the pump runs continous, with the ignition on and pump running you should have a controlled system pressure of approx 3.5 bar, then if you block the pipe that goes from the warm up regulater to the metering head( its next to the tank return union on side of metering head) the pressure should if all is working correct go up to approx 7.0
if either of these are out of range, ie not enough pressure the K jet system over fuels, and no amount of tweaking the CO% will cure it
If you have no control pressure there are two ways you can fix it, first is to replace the warm up regulator with another known working example, then re test the system as described above.
Or
Replace the warm up regulater with a different pressure regulater, a 2wd Cosworth item will be best as that runs at approx 3.5, and has push on hoses so can be easily fitted to you system, but this will affect cold starting a little, but shouldnt be that noticable
hope its of use to you.
Old Aug 18, 2005 | 11:03 PM
Martein's Avatar
Martein
Hi,
thanks for your reply!
It was sorted, well... the car was drivable, but nothing more than that.
I've now decided to sell the engine and all it parts, and go for a full zetec conversion on throttlebodies
I already bought several parts (engine, RST S1 gearbox, 4-2-1 ss manifold 5speed gearbox kit) hopefully the parts arrive soon, so I can begin !
I'll keep you all updated !
Martein
martynhomer01
Oct 1, 2015 12:05 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
Sep 28, 2015 10:05 AM
