Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS1600i dash lights
Old Nov 16, 2003 | 07:26 AM
Default RS1600i dash lights
Can anyone think of why the 2 little lights on my dash have stoped working for no reason at all.
What are they ment todo dont think they ever worked properly, no they do less than that.
any help?
Old Nov 16, 2003 | 12:35 PM
rs1600i's Avatar
rs1600i
The two lights above the speedo (red and amber) both mean the same thing! They show that the fuel cut off is working! They should come on when you are off the throttle and deaccelerating from1600rpm and above! They will only work if the car is still running the Twin coil set up! Theres a few things to check. A wire that goes to the throttle body this completes a circuit when the throttle is fully closed. Make sure its clean on the connector at the end and where it connects to! Also theres a valve on top of the air box where another wire goes to make sure that connectors clean! That valve could be broken! So make sure that car is warm at use the throttle body to rev the car! As long as you rev it over 1600rpm you should be able to hear the valve open and close(it makes a weird noise) I think this is right but if im wrong the lad's will sort you out on here! simon
Old Nov 16, 2003 | 03:41 PM
paul cox's Avatar
paul cox
all sounds correct to me that.
also - the valve's could be a bit dirty on the inside,spray some brake cleaner at them,to clean um up.
Old Nov 16, 2003 | 04:22 PM
Thanks will check all that I think it might be the valve it just stoped working while driving.
Old Nov 19, 2003 | 05:52 PM
RS1600ireg's Avatar
RS1600ireg
S1 RS Turbo Registrar
If the above does not work, theres a male switch with two prongs on@ the rear of the plenum chamber ( underneath) its common for one of the wires to come off(if one of the two wires has...replace!) Also if you have a spare ECU swop them over, its also common for this to be an ecu fault ( car runs perfect apart from this).
Old Nov 19, 2003 | 09:47 PM
rs1600i's Avatar
rs1600i
does it matter which way round them wires go under the plenum chamber?
Old Nov 20, 2003 | 07:09 AM
paul cox's Avatar
paul cox
um - dont thinks so
Old Jan 10, 2004 | 04:14 PM
Checked all this replaced ECU checked switch, and replaced valve, still broken
when you turn the ignition on the flash quickly thats it.
Help
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
imnoteasy
Sep 7, 2015 09:26 PM
