Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
weird electrical problems with headlights
Old Feb 13, 2015 | 04:19 PM
Antony Mann's Avatar
Antony Mann
Default weird electrical problems with headlights
ok so recently my main beam has stopped working , high beam works only on the left side, side lights and low beam both work and all rear lights work , only weird thing is that the central locking stops working when the main beams stop, ive checked fuses and earths, ive swapped relays around to see if that would change things, light bulbs and put in a new battery, nothing, but then as randomly as it stops working I can be driving along and they will all start working again for a day or so then stop again, I have no idea what im supposed to do, I cant keep driving using low beams and fogs at night , im stuck and getting desperate for help
Old Feb 13, 2015 | 04:20 PM
paul16v's Avatar
paul16v
Monte 087
Fuse box? common problem.
Old Feb 13, 2015 | 04:22 PM
Antony Mann
have had someone mention that it could be either the fuse box or stalk switches
Old Feb 13, 2015 | 08:19 PM
STeve's Avatar
Super Moderator
stalks are well known to cause many issues but unusual for central locking faults to arise from stalks no doubt why paul suspects fuse box
Old Feb 15, 2015 | 11:34 PM
Antony Mann
cheers ill see if I can find one, apparently it needs to be the same code or something
Old Feb 16, 2015 | 06:24 AM
Fordmad!'s Avatar
Fordmad!
Just takr yours off and dry it out. No doubt you have a leak that's letting moisture in
Old Feb 16, 2015 | 11:03 AM
cossiestu's Avatar
cossiestu
As above, fuse boxes and stalks were common. Don't know if it's still the case, but, from memory of working at Ford, there were quite a few different boxes and you had to get the Ford part number off it to get the right one. The stalk obviously differ with the wiper functions, that used to catch a few out, was amazing the amount of customers couldn't remember if they had variable wipe?!
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
focus2351
Sep 9, 2015 09:33 PM
