Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Heater matrix
Old Dec 19, 2014 | 07:32 AM
Fordmad!'s Avatar
Fordmad!
Default Heater matrix
Any tips on replacing a heater matrix? New thermostat hasn't sorted it out.
Anything else I can try to get heaters working before I get the dash out?
Old Dec 19, 2014 | 12:29 PM
RichieST's Avatar
RichieST
Is it blocked? Tried some rad flush? Or try disconnecting the hoses on the back of the block and blasting a hose down there.
Old Dec 19, 2014 | 03:10 PM
Fordmad!'s Avatar
Fordmad!
Yes im going to try that first. Not got a outside tap fitted yet though :/ May change matrix in the summer I think anyway.
Old Jan 26, 2015 | 06:32 PM
Fordmad!'s Avatar
Fordmad!
Right im off work tomorrow so going to take the dash out and change the matrix as I still have no heaters
Ive already changed the thermostat, is there anything else I can to get them working before I do the dash?
Also does anyone know how to remove the steering wheel?
Old Jan 27, 2015 | 06:01 AM
STeve's Avatar
Super Moderator
unplug the yellow cable above brake pedal, remove steering shrouds get a 5.5mm socket and undo 2 bolts on rear of airbag, pull airbag off disconnect the yellow plug, then get 15mm socket and loosen the centre nut, insert ignition key and turn one click to lower steering lock and wiggle the wheel off complete with airbag ring and yellow cable attached
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
