Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
mk5 escort refuses to start ?
Old Mar 28, 2013 | 08:58 PM
rsguy's Avatar
rsguy
Default mk5 escort refuses to start ?
my mk5 escort has been stood unused for a few years today i removed the old fuel.
i removed all the fuel it was urine colour so i gather it was stail fuel. as new fuel is a clear colour.
i removed the fuel by taking the pipe off the fuel regulator and kept turning ignition on and off.
i replaced with new fuel now the car refuses to start? when i first tryed to run car after putting new fuel in it backfired a couple of times after turning over.
the pump seems ok as i can hear it prime and then turn off.
i took out plugs and dryed them cleaned and refitted them, the car tryed to start but just will not fire.
im stumped as it did run eventully on the old fuel. and now wont start at all with new fuel in?
Old Mar 28, 2013 | 10:16 PM
RichieST's Avatar
RichieST
When you emptied the tank it might have pulled all the shit through from the bottom of the tank with it. Blocked filter maybe? See if it fires on easy start or something.
Old Mar 28, 2013 | 10:39 PM
rsguy's Avatar
rsguy
ok thanks i will buy some easy start tommorow.
i pulled the fuel regulator pipe back off and i can see the new fuel is comming through ok. so do you think the filter might still be blocked if theres fuel getting through?
Old Mar 28, 2013 | 10:41 PM
RichieST's Avatar
RichieST
Without looking at it I have no idea. Could be many things. Presume you have ruled out weak battery etc?
Old Mar 28, 2013 | 10:49 PM
escort-really-an-orion's Avatar
I take it you tried starting first....then took the fuel out? Mine refused to start but it started the day before fine.
Changed the leads and plugs then started tho really rough so cleaned the injectors ect out and she started like a dream.
Im going to say its dirt clogging something.
Old Mar 29, 2013 | 01:45 PM
rsguy's Avatar
rsguy
ok thanks should i just buy some redex and put it in tank to clean the injectors?
Old Mar 29, 2013 | 07:45 PM
Yeah, that alone will do it the world of good. Tho what you could try and I did this with mine today is take the plugs out and pour about 500ml in to each of the combustion chambers and left it to stand (about an hour while i changed the oil).
With the plugs still out turned the engine over for about 10 secs. Tho as pretty as the fountain of redex shooting up I should have put a towel to stop my engine bay getting covered!
Put the plugs and leads back in and the amount of crap that was thrown out was shocking!! Worked a treat as there is no carbon at all in the chambers and my injectors are gleaming!
I did squirt a load of spray injector cleaner into the throttle body and redex in the take to make sure.
Give it a bash, worst that can happen is it wont start!
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
