Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
alternator help
Old Jan 15, 2013 | 10:28 PM
Northants Ford Fan's Avatar
Northants Ford Fan
Default alternator help
Hi guys.
I'm after a new alternator for my 1.8si cabriolet as on full load (lights heated screen and stereo on) it can only put out about 11.4v's. so my question whats the highest amp alternator that will fit it ? , and if not a escort one what car does it come from so i know which one to quote when ordering it, as while I'm changing it i might aswell upgrade it ready for the stereo upgrades i have planned.
cheers
Old Jan 16, 2013 | 07:58 PM
Northants Ford Fan
Anyone ?
Old Jan 17, 2013 | 08:45 PM
JOHNDQ's Avatar
JOHNDQ
Are you sure the alternator just isnt faulty mate
Old Jan 17, 2013 | 08:51 PM
martysmartie's Avatar
martysmartie
You will need a high output, the heated screen draws massive current, I assume you added this?
80A I would say you need, a Mondeo one would fit, as I guess yours has the same "Zetec-E engine".
Martin
Old Jan 19, 2013 | 05:11 PM
minder's Avatar
minder
why don't you use one off a diesel escort they have a much higher voltage done this many times over the years and always works with no problems
Old Jan 20, 2013 | 01:15 PM
martysmartie
Amperage, not voltage
OP, you need to establish what one you already have, with that screen you will want one sutiable, the Escort Diesel (70A, IIRC?) may not be suffice.
Martin
Old Jan 20, 2013 | 02:02 PM
cabriolet's Avatar
cabriolet
i take it your car has power steering fella they list a 70 amp alty for this [the non power steering version of yr car uses 90 amp] its physically bigger but if u got room jobs a good un
Old Mar 25, 2013 | 08:39 PM
Northants Ford Fan
update on this went for the 90a non power steering alternator which fitted fine only difference was the wiring layout was slightly different.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
