Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
fuel pump???
Old Dec 14, 2011 | 05:01 AM
wedge07's Avatar
wedge07
Default fuel pump???
Hi i have a mate whose car clonked out on him. Said hes gettin no fuel up top. Any ideas. Where is fuel cut off switch. Relay n fuses etc? Colours of relays? Any help would be appreciated cheers n its a 2wd rs2000 mk6.
Old Dec 14, 2011 | 07:09 AM
SteveB's Avatar
SteveB
These quite commonly split the rubber pipe in tank.... Simple replacement once the tanks out
Old Dec 14, 2011 | 07:22 AM
Fordmad!'s Avatar
Fordmad!
Can you hear the fuel pump whine when you turn the key?
Had an rs2000 vam and the wire came off the fuel pump on mine.
Just check that first. If i dosnt kick in check the relay, pump itself and the cut off switch.
Had that go on my escort van just would start one morning. If i primed the filter it would run for 2-3 seconds then die so this could be his problem as they just go suddenly!
Old Dec 14, 2011 | 07:46 AM
STeve's Avatar
Super Moderator
cut off switch is in drivers side kick panel
Old Dec 14, 2011 | 02:16 PM
wedge07's Avatar
wedge07
No fuel pump is kicking in no. Where is relay? Cheers
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
