Mk 5 2wd to 4wd conversion
Hi all
My mate wrote off his Mk5 RS2000 4x4 :-(
If he gets another shell, for a 2WD, can you remove the running gear from the 4x4 and put them on the 2WD as a bolt on job?
Someone mentioned to me that you can but I doubt it.
Thanks
Thanks
the shells are different. on the 4x4 the spare wheel well is shallower giving room for the transfer box and shaft. it mite be possible but i think it would be quite hard to do
It tells you the differences here, the wheel well as mentioned above and a different fuel tank.
http://www.rs20004x4.co.uk/buyersguiders2000.htm
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
