Tardis
Old Feb 25, 2012 | 02:48 PM
fezzaboyy's Avatar
fezzaboyy
http://a8.sphotos.ak.fbcd
Default Tardis
Do I just spray and wait or is it not that simple
Old Feb 25, 2012 | 04:53 PM
jock05's Avatar
jock05
Yes spray and watch it dissolve tar. I assume that's what you are using it for.
Old Feb 25, 2012 | 08:32 PM
P4ULT's Avatar
P4ULT
It's best to use when the car is wet I have found. A good tip I was told if there is lots is to spray it on then use paper towel to let it soak for longer and then wipe of after and make sure you rinse really well after use. It will also strip any protection on your paint.
Old Mar 5, 2012 | 10:02 PM
RussZS's Avatar
RussZS
Spray it on, let it do its thing for about 3 minutes or so, then wipe off with a MF towel. If you have some larger/persistent spots, spray some Tardis onto your MF and work it gently and it should lift. For larger chunks repeat the process.
Don't let it dry and don't use it on hot panels or direct sunlight where possible.
Polished Bliss
Concours d'élégance.
Oct 20, 2010 08:48 PM
Polished Bliss
14
Sep 27, 2009 10:12 AM
Polished Bliss
May 4, 2009 03:56 PM
