Removing Green Moss?
Old Apr 24, 2011 | 11:06 AM
COCHYN's Avatar
COCHYN
Default Removing Green Moss?
Well she's been sitting for about 6 months around some trees, and the fresh paint work had not got green moss settled in various parts of the exterior i.e. bump strips, wing mirrors etc.
I did remove it all after a good long, lengthy wash when I originally bought the car. But now I want to pick your brains and see if you have any simpler options. Its not a big problem, but enough for a days work of cleaning because its not been sitting "that" long. But options other than pressure wash it off which may chip the paint in some areas would be most appreciated
Come on bufty's
Old Apr 24, 2011 | 11:15 AM
cabriolet's Avatar
cabriolet
cut down paint brush neat fairy liquid then a bloody good wash afterwards
Old Apr 24, 2011 | 11:19 AM
COCHYN's Avatar
COCHYN
Ah, roughly what I did previously then Guess it won't be as bad as last time because it had been sat for a couple of years. Cheers
Old Apr 24, 2011 | 11:21 AM
cabriolet's Avatar
cabriolet
allways works for me bit labour intensive but no scratches etc
Old Apr 25, 2011 | 04:38 PM
BM08's Avatar
BM08
Ive got some annoying green bits when your sat in the car you can see on the rubber through the glass near the bottom of the window.
Would an old toothbrush do?, not sure if it would get in between the glass and the rubber?
Old Apr 25, 2011 | 05:01 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
jet wash then remove lights, window mouldings etc to get round the backs
Old Apr 25, 2011 | 05:11 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Toothbrush and some apc will work just fine,pressure washer works aswell
Old Apr 25, 2011 | 05:22 PM
COCHYN's Avatar
COCHYN
I wouldn't, don't want to chip paint.
Old Apr 25, 2011 | 05:42 PM
BM08's Avatar
BM08
tooth brush and apc sounds good, nothing could go wrong with that?
Old Apr 25, 2011 | 05:46 PM
COCHYN's Avatar
COCHYN
Nah, but I just wanted to see if there was any other options from last time. Nothings easy
Old Apr 27, 2011 | 09:27 PM
st170dan's Avatar
st170dan
dont do this!! clay is the safest and best way to remove moss.
boeb
Jan 9, 2020 05:11 AM
timsrs
Nov 13, 2018 11:48 AM
Orion_Gav
Sep 29, 2015 04:50 PM
