T Cut v's Clay bar
Old 29-12-2010, 06:01 PM
chris m1
chris m1's Avatar
Default T Cut v's Clay bar
simple question, which ones better?.. got some halfords vouchers for crimbo so thinking of some new polishing goodies.
Old 29-12-2010, 06:05 PM
Icurus
Icurus's Avatar
Clay bar in my humble opinion
Though T-cut is ok for really stubborn marks......
Fil
ELASTIC BAND
Fil's Avatar
there not vs products?
get some clay tho. used after a wash to remove all the crap stuck on the body work, then polish and wax
avoid t cut like the plague
Old 29-12-2010, 06:08 PM
Magnum PI
Magnum PI's Avatar
Cay bar every time,
you can also get liquid clay bar from Halfords, its that 'Ice' wax/polish stuff, its pretty good.
Other than that, get Meguirs crystal paint clenser stage 1, 2 & 3, plus the clay. that'll pretty much do it
Gav Diamond
Gav Diamond's Avatar
One is a compound for polishing (T-cut) and the other is for removal of surface contaminants (clay bar) so not really comparable mate.
Old 29-12-2010, 06:10 PM
marc_gti
marc_gti's Avatar
as said above you cant Vs Clay against t-cut they are two completly different things.
Avoid t-cut and instead buy some Clay - then you polish then wax - from there onwards all you need to do for the next 6 months is top the wax up, then after 6 months polish again
CraigoScott
CraigoScott's Avatar
they dont do the same thing so cant be compared? T cut is a non diminishing compound, clay bar is a clay bar for removing contaminants. if you want to remove contaminants get a clay bar, if you want a compound get some auto glym super resin instead of T cut, t cut is rubbish really
Old 29-12-2010, 06:11 PM
BigChuck
BigChuck's Avatar
as said,
T cut is a polish
clay bar is a bar of clay that you use to remove containments before polishing
they both do different jobs
Old 29-12-2010, 07:24 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
As said above, you can't compare the 2.........
Really, did we need to tell the guy that like 5 times???????
Old 29-12-2010, 07:27 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Indeed, its like saying "888 tyres or a T34 turbo which is better?"
What is it you are trying to achieve?
Clearing contaminants = clay bar
Revitalising faded paintwork = t cut
Old 29-12-2010, 07:30 PM
D.K.
D.K.'s Avatar
Clay bar all the way for smooth paint
Old 29-12-2010, 08:43 PM
xr2john
Passionford Addict
xr2john's Avatar
it all depends what your looking to achieve at the end of the day. but as everyone has already pointed out,t-cut and a clay bar are 2 totally diffrent things.But unless you really know what you are doing stay away from the t-cut as you could end up doing your paintwork more harm than good belive me.if you rub too much you could in theory strip all the laquer of your car
Old 29-12-2010, 08:50 PM
matts1
matts1's Avatar
get the clay bar and give yourself a good day of detailing on the car.
The clay bar will remove git and dirt without removing paint leaving the surface properly cleaned, meaning when you polish it will go on and come off more easily, will give a better result, and the most important, wont be draging grit around as you polish.
t-cut should only be used to remove stuborn marks that wont shift with the clay as it works by cutting through the surface..
Clay is very quick and easy to use and will make future polishing sessions far less graft, do a quick search on youtube for it to see how it is done. It is 100 x easier than t-cuting a car.
Old 29-12-2010, 09:03 PM
jaiscossie
jaiscossie's Avatar
Out of the two its very close as to be honest i think there both as good as each other but i think the t34 just pips it.
Old 29-12-2010, 10:24 PM
gjh
gjh's Avatar
Go easy on the t cut, its quite strong, can do more dammage than good. Clay bars are brilliant.
Old 29-12-2010, 10:33 PM
stevieturbo
C**t
stevieturbo's Avatar
Fuck either, pay someone else to do it !
Old 29-12-2010, 11:03 PM
pee vee
pee vee's Avatar
very expensive option! that cost me Ł300 last month! LOL
Old 29-12-2010, 11:04 PM
chris m1
chris m1's Avatar
Well they say you learn summat new everyday so..As far as I was concerned they both served to clean/freshen paint.
Looks like a claybar then, got plenty of megs stuff so should finish it all off
Old 29-12-2010, 11:05 PM
pee vee
pee vee's Avatar
yeah, clay bar and quick detailer as they usually come in a box together,
and it should make your paint all nice and smooth
Old 29-12-2010, 11:16 PM
stevieturbo
C**t
I'd imagine that was a bit more than a polish though ?
If doing DIY for the same job, how much time would it take, and how much money on buying crap to do it with ?
Old 30-12-2010, 08:20 AM
Chip
Chip's Avatar
Im not really into all the polishing side of things myself, prefer the mechanical aspects of cars, but my mrs loves detailing and its certainly easy to see how she feels a sense of pride with results like this on my corsa she did, which was pretty ropey when I first got it:
This is it halfway though:
Old 30-12-2010, 08:38 AM
marc_gti
marc_gti's Avatar
what polish did you use to get that finish? when i bought my mk6 gti that was faded aswell and i used Super resin polish then kept it topped up with wax
Old 30-12-2010, 08:52 AM
Chip
Chip's Avatar
Not sure what make polish it is, she did it with her machine polisher, I can ask her though.
Your escort looks like you have got good results anyway though
Old 30-12-2010, 08:54 AM
pee vee
pee vee's Avatar
red cars are prone to fading aint they,.. but when they are done, they look so bright!
that GTi looks wicked!
Old 30-12-2010, 08:59 AM
Chip
Chip's Avatar
Yeah the vauxhall "flame red" colour for example is often referred to as "flame pink" on the vauxhall forums because of how much it fades!
Not the only colour that does so though, my mrs showed me a blue one recently that was even more dramatic, it was practically white on the before pics!
Old 30-12-2010, 11:23 AM
Derby_Gav
Derby_Gav's Avatar
I don't trust my mrs with a car, let alone taking a polisher to one! Lucky bloke!!
A full day on the car starting with a good wash, clay bar, maybe a t cut, polish then wax should see it looking loads better.
Gav.
Old 30-12-2010, 11:59 AM
TheRooster&TheScorpio
TheRooster&TheScorpio's Avatar
Default Comparisons that don't add up.
Not quite Gav. What is not disclosed by Chris, is whether the paint is a Solid Colour or a Metallic/Two Pack. T-Cut is/was a compound for the removal of Oxidised Paint on the surface of Solid Colours.It will destroy the lacquered finish on Metallic Paints/Two-pack. If there is now one for Metallic/Two Pack then I will hold my hands up on that!!.The surface has in all cases to be thoroughly cleaned & dry before applying T-Cut. Liquid Ice & Ice Paste are both products from Turtle Wax,they are a polish (two one many). The beading quality of the paste is quite exceptional. I was recommended to the paste by the Customer Service Technical Desk at Turtle Wax. The best product that I have used for the cleaning and removal of fine scratches on a Lacquered Finish is Q3 . Solid Red has got to be the most notoriously affected of all of the Solid Colour Paints. The variants of red do not seem to be troubled quite the same and Metallic/Two-Pack reds seem to withstand the colour loss. Even after hours of work to restore the colour/finish they will often revert back to faded. I have just collected a Scorpio Estate that had a Diamond Bright treatment some years ago and it is still looking good, even after a 200 mile drive back home after collecting it from Reading with all of the Winter Crap on the roads.
Old 30-12-2010, 12:03 PM
stevieturbo
C**t
The detailers certainly can produce fantastic results.
But fuck that. Washing is enough cleaning for me !!
I think Ive polished my Granada about 5 times since I bought it....and that was 2002 lol
Old 30-12-2010, 12:10 PM
chris m1
chris m1's Avatar
cheers Rooster.
The car is a solid colour (certainly doesnt shine like like mettalic paint anyway),its an old peugot blue..poss admiral blue.
The brightworks doesnt seem to have seen any polish/ tlc for a fair while hence the reason for wanting to get some of the luster back into it
Old 30-12-2010, 01:00 PM
Originally Posted by chris m1
cheers Rooster.
Hi Chris,I will dig out the Q3 and a few other detailing & polishing/goodies & put them on the forum in a day or so.
Old 30-12-2010, 01:10 PM
chris m1
chris m1's Avatar
cool..carnt do anything outside as its to wet and foggy so no rush
Old 30-12-2010, 01:29 PM
Gav Diamond
Not sure if you have quoted the right person bud but T-cut is a polishing compound, colour or type of paint is irrelivent really as the product is what it is.
Yellow and blue are and can also be as sevier (spelling?) in some cases
To restore a faded colour to its original gloss you have to polish (ie, you are removing a certain amount of the top layer of paint) it is best to then apply a quality glaze..this is basically like moisturising skin to stop it drying out, the same goes for paint.
HTH
Old 30-12-2010, 01:34 PM
Gav Diamond
Done a really faded red myself..
Bonnet 50/50
Bonnet finished
Old 30-12-2010, 08:02 PM
big mac
big mac's Avatar
http://www.polishedbliss.co.uk/acata...ing-paint.html
have a read fella tells you all about claying and if you look here
http://www.polishedbliss.co.uk/acata...re-advice.html
lots of very good advise and tips
john at pb will also help you with choice of product to get that show car look if you are unsure
hth
Old 30-12-2010, 09:19 PM
Chip
Chip's Avatar
Hell of an improvement Gav!
Old 31-12-2010, 02:56 AM
Gav Diamond
Cheers bud, I learnt a big lesson on that car....do not tape up a 50/50 like that on faded cars as getting rid of the sharp line is a nightmare, lol
Old 31-12-2010, 04:13 AM
Received 1,044 Likes on 998 Posts
As said clay bars are really good.
Old 31-12-2010, 07:28 AM
Chip
Chip's Avatar
LOL
Old 31-12-2010, 07:23 PM
TMC225Y
TMC225Y's Avatar
Normal T cut, the stuff in the red bottle, is only suitable for solid unlacqured colours, cellulose paint basically. It contains ammonia which creates a cloudy effect on clearcoats. Metallic t cut has no ammonia, but I don't use it, so can't really comment on how good or bad it is. If the paint is quite good, go for the clay bar, then a good wax, if it's really bad, I would normally machine mop it with fine cutting compound, G10?, then polish and wax. I'm no expert, so i'm not saying it's the right way, but it's the way I do it
Old 04-01-2011, 09:56 PM
Garfiun
Garfiun's Avatar
I love using the clay bar it really brings the hard crap off the paint work and once polished leaves a lovely finish.
Quick Reply: T Cut v's Clay bar
