Which Silver paint to use on....
Old Jul 28, 2010 | 12:18 PM
Cossy Mike's Avatar
Cossy Mike
Default Which Silver paint to use on....
My Front and Rear Diff, also the gearbox.
I have all of them off the car and I have bought some Upol 8 Acid etch primer but what type of paint and what type of Silver is nearest to original finish that will cope with the heat??
thanks!!
Old Jul 28, 2010 | 07:51 PM
Shilly's Avatar
Shilly
halfords do a high temp paint in silver it should do the job
Old Aug 5, 2010 | 04:31 PM
opposite lock's Avatar
opposite lock
i,ve never used it but have heard/seen in the resto room on here , makes them look new again with heat resistance qualities
http://www.frost.co.uk/item_Detail.a...ductName=Aluma
hth
Old Aug 5, 2010 | 05:00 PM
Cossy Mike's Avatar
Cossy Mike
hth
Thats the product I've chosen to go with .
My only concern is, am I able to laquer it afterwards ??
Not got a reply back from them....
Old Aug 6, 2010 | 12:31 PM
opposite lock
maybe stick a thread in GD mate , i,m sure you,ll here lots of good opinions on the laquer situ
mike
Old Aug 7, 2010 | 12:23 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Hi Mike
I always use Aluma Blast on freshly blasted cast aluminium as its the closest match i could get to make it look original.
I then finish off with Eastwood diamond Satin Clear lacquer.
Before painting i usually outgas the aluminium in the oven for 10 mins but this is not necessary, Its just for my piece of mind
A few customers parts below fully restored.
Hope this helps and gives yo an idea of the finish it produces.
Chris @ PRP
Old Aug 7, 2010 | 12:34 PM
james kiely's Avatar
james kiely
they look mint chris
Old Aug 8, 2010 | 08:37 PM
opposite lock
they look the bollox Chris , the metal work too
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
