few tips needed peeps
Old Jul 21, 2010 | 04:52 PM
saph4be's Avatar
saph4be
Default few tips needed peeps
one thing i allways struggle with is makin the carpets look mint in our lass's car no matter how much i hoover them i can never seem to get everybit up does any one have any tips to remove these stubborn bits of muck
and also what is a good polish/paint renovater to use as her car seems to be covered in swirl marks for some reason so any tips to remove/mask these as they look awfull thaks
Old Jul 22, 2010 | 09:38 AM
Rsmat's Avatar
Rsmat
try a wet hoover to lift even more muck off the carpets..should do the trick
without seeing the paintwork i carnt give you an exact "WHAT TO USE"...but the genera stuff i use is either dodo juice lime prime orfor really light stuff autoglym super resin.
Old Jul 28, 2010 | 12:03 AM
RSEDD's Avatar
RSEDD
For my carpet mate...(FRST).....bit extreme i know, i took the whole carpet out and Karchered it using carpet cleaner and jet washed with a turbo lance, then hung it up on a wall to drip dry...PERFECT AS NEW!!!
Ive also done this previously to another FRST, grey carpet, which had been sitting in a breakers for a number of years, and was 4 inch thick in leaves, mud and shite.....This came up AS NEW!!!
As mentioned, i am anal, but if you dont fancy Putting the Karcher on it then a 3-in-1, carpet cleaner together with a machine vac might suffice??? Depends on how stubborn the dirt etc!!
Hope this is of help??
mk22door
49
Mar 26, 2022 07:15 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
muffster
Aug 12, 2015 08:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
