paint depth/hardness-
Old Oct 13, 2009 | 07:49 PM
opposite lock's Avatar
opposite lock
Default paint depth/hardness-
i want to know the above on the saph,its been resprayed before i bought her so bit of a lottery choosing correct products for polishing etc, is there reasonably priced depth reader for keen amateurs and can they tell you the hardness?
Failing tht , is there a good place i can goto for testing the depth and hardess?
dont mind travelling to find out!!?pb is too far tho lol
cheers mike
Old Oct 13, 2009 | 10:07 PM
jock05's Avatar
jock05
One of the cheapest I seen: http://www.paintdetective.com/?gclid...FaBb4wodn3q7kw
Old Oct 13, 2009 | 10:34 PM
boost mad's Avatar
boost mad
Thats pretty much the same as the one i use, except mine doesnt have the funky backlight.
Does the job tho, just make sure you calibrate it before every time you use it
Old Oct 14, 2009 | 04:15 AM
Gav Diamond's Avatar
Gav Diamond
As for hardness it is not something you can measure with a gauge or meter etc.
Just start with the least abrasive polish and work up the scale of polishes and pads if needed.
Old Oct 14, 2009 | 03:53 PM
opposite lock
ok cheers for that ,nice one pal i,ll try tht
Old Oct 15, 2009 | 01:15 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
if it's been sprayed to a decent finish, you'll be able to polish a fair bit til you break through the lacquer with a fine polish. even with rotary.
if you've got a Meg's G220 DA polisher then even better + safer.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
