overspray
Old Jan 31, 2009 | 07:02 PM
craig2351's Avatar
craig2351
Default overspray
as above ive just fitted a new front panel on my escort but ive got overspray on the wing, whats the best way to remove it cheers in advance
Old Feb 1, 2009 | 09:59 AM
Gav Diamond's Avatar
Gav Diamond
I would say the best way is to get your self a clay bar kit.
If you do not want to order online i think you can get a kit from Halfords for about Ł20 that comes with everything needed and instuctions on how to use.
Infact just done a search on there site and they have there own or a Meguiars kit
http://www.halfords.com/webapp/wcs/s...0151&langId=-1
Myself personally i would spend the extra and get the Megs kit.
Just make sure you wash the car first and make sure the panel is well lubricated when using the clay bar
Most clay bars you will be able to split down into 3 or more pieces so you can do a few cars but should you drop the piece you are using discard it as it will pick up dirt you cannot see and will mar the paint
If you want to buy online a good cheap one would be the Bilt Hamber clay http://www.bilthamber.com/autoclaybuy.php the best bit about this clay is you use water as the lube so no need to buy or use expensive quick detailers or dedicated clay lubes.
I have never used the above but have seen some good reviews on it.
Just a few options
Hope this helps
Old Feb 1, 2009 | 10:06 AM
fuzzy's Avatar
fuzzy
14000+ post superhero
i rubbed it out on my touring with rubbing compound then polished it up but mine is flat white with no laquer.
Old Feb 1, 2009 | 02:52 PM
craig2351's Avatar
craig2351
Just a few options
Hope this helps
thanks gav i nipped to halfords before and bought myself some meguairs quikclay worked a treat, car looks alot clearner now to thanks again
Old Feb 2, 2009 | 05:15 PM
Gav Diamond
Glad you got it sorted bud
155lee
Oct 24, 2015 11:11 AM
paceo
15
Oct 17, 2014 10:11 AM
Ezzel_rs
Sep 25, 2013 02:22 PM
Clark@Polishedbliss
Concours d'élégance.
27
Jul 22, 2009 05:50 AM
