laptop prob
Old Apr 12, 2005 | 10:44 PM
nigel b's Avatar
nigel b
Default laptop prob
got a shite little laptop
it recognizes and tries to read the flooppy but cant read anything off ot no matter what is on the disc
it cant write to it either
also the pcmcia slots aint working
Old Apr 12, 2005 | 11:55 PM
Adrian's Avatar
Adrian
PCMCIA could be a driver issue.
FDD sounds stuffed to me.
What laptop you got?
Old Apr 13, 2005 | 04:52 PM
DanRSturbo's Avatar
DanRSturbo
If you insert a floppy disk and switch the laptop on, does it come up with invalid system disk error ? What operating system is it ? Dos test will confirm the fault
Old Apr 13, 2005 | 10:35 PM
nigel b's Avatar
nigel b
its using nt4
i only want it so i can use win 98 and connect it to the car
adrian
if i cant use the floppy as i cant install pcmcia drivers,even tho in system32 it has the drivers for floppy and pcmcia
Old Apr 27, 2005 | 06:28 PM
DanRSturbo's Avatar
DanRSturbo
If you have NT4 on it, you'll have a few issue's putting windows 98 on it, you'll need to format the drive into FAT 32, Neither the windows 98 boot floppy, nor cd-rom will recognise the current NTFS file system, and won't allow an installation A dos test will determine if the floppy works or not, and the pcmcia slot's could still be a driver issue, did the laptop come with nt4 on it ?
Jun 26, 2017 06:18 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
