Windows 8 Problem
Old Dec 19, 2013 | 11:46 AM
Brian's Avatar
Brian
Default Windows 8 Problem
I have the lastest windows on my laptop and it updated yesterday automatically, but for some reason I go to my account on the start up screen enter my password and then the screen goes blank
But if I sign into my wifes account it logs in and works
Anyone got any ideas as too why it will work with one account but not the other?
Brian
Old Dec 19, 2013 | 12:41 PM
martysmartie's Avatar
martysmartie
It sounds like your profile is corrupt, your question implies you have Windows 8.
Unfortunately with the new OS's, it is not straightforward to create another profile, as you need to modify a registry key as well, which unless you are comfortable doing, has potential for serious damage.
I can tell you how to rename your profile and make the change to the registry if you are comfortable doing this?
Alternatively you could create a new account, but then you obviously this will not have your data, both achieve the same end result, but the latter is easier and your data can then be transferred...
Martin
Old Dec 19, 2013 | 01:19 PM
Graham S1's Avatar
Graham S1
Martin
Can't you just copy the files across from the 'User' directory? Not played much with Win 8 yet.
Old Dec 19, 2013 | 01:29 PM
user 628729's Avatar
user 628729
I've read about this problem elsewhere, some sort of bug when updating W8;
assuming you have Administrator access doing this is the easiest solution.
Old Dec 19, 2013 | 05:26 PM
Brian's Avatar
Brian
I've tried doing a system restore but still in my account administration account its dead slow
Ive logged in to the wifes account and its fine?
How do I go about creating a account as I think likes been said here and a quick look on line my account may be corrupt
Brian
Old Dec 21, 2013 | 09:45 AM
martysmartie
Go into 'Settings' as it's known in W8.
Look for 'User accounts' or a name along those lines, haven't looked at W8 much.
Then in here select the create a new account option, fill in the required details and you are done.
As said though, this is assuming your working account is an Administrator.
Martin
Old Dec 21, 2013 | 10:03 AM
martysmartie
Yes, he could do that into the new profile once it's created, that is what I said by transferring the data across.
Martin
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
pabloXR
Sep 21, 2015 12:42 PM
Flateric_2002
Sep 15, 2015 08:41 AM
