Hot computer
Old Feb 22, 2005 | 01:59 PM
rstoughy's Avatar
rstoughy
Default Hot computer
Installed my Broadband last night and since then have noticed that my pc is running around 10 'C hotter. Is this correct or should i be worried . PC has a tripple fan power supply and a separate fan in the side of the case plus the one on the CPU so surley this should be enough.
What do you think.
Paul.
Old Feb 22, 2005 | 06:54 PM
DanRSturbo's Avatar
DanRSturbo
If you've got a USB modem then it is possible that there could be a little juice used to power the modem, thus making it slightly hotter, but 10 degree's from a modem is a bit eccessive IMO
Unless, you're hammering the net like I do and it's your hard drive getting a bit hotter. What temp does it run ?
Old Feb 22, 2005 | 07:49 PM
morto's Avatar
morto
hi mate, broadband should have very little to do with it..
andzz
Old Feb 22, 2005 | 09:10 PM
rstoughy's Avatar
rstoughy
Got to admit ive been a bit busy hitting the net now that i can click on a page and it actually opens.
according to the temp read out on the CPU it usually sits around 26-28 deg but since i installed the modem (external USB type) lastnight and started browsing it has risen to 35-36 deg dunno just dont want to fry the PC as i just built it before Christmass
Old Feb 23, 2005 | 06:45 AM
Martyn's Avatar
Martyn
My CPU usually sits anywhere between 40-48 and ive never had any probs, its left on 24/7 too
Old Feb 23, 2005 | 10:31 AM
rstoughy's Avatar
rstoughy
cheers guys,
AJC
Oct 1, 2015 06:47 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
