D link router
Old Feb 9, 2005 | 09:26 AM
m1ke's Avatar
m1ke
Default D link router
Have connected this to pc but then couldn't find a driver on the disc that came with it and cant get online, kept getting unable to establish a connection
Any ideas???
Old Feb 9, 2005 | 09:45 AM
EssexBoyRacer's Avatar
EssexBoyRacer
driver?
How are you connecting to it?
Its normally connected via ethernet so you setup the router through its HTTP page.
http://[ip_address_of_router]
Old Feb 9, 2005 | 09:57 AM
m1ke's Avatar
m1ke
Cheers for the reply, not exactly a computer genius
Assumed it needed a driver as on the contents list it says
CD-Rom containing manual and usb driver
confused me as it has no usb connection
Cant connect to http page, thats when i get the unable to establish a connection message.
When i click on the the lan connection properties thing its says connected and working correctly, prob a setting i have missed
Old Feb 9, 2005 | 10:01 AM
EssexBoyRacer
you will need to set the IP address of your machine in the same range as the router.
If the routers IP address is for example 192.168.0.1 make your PC 192.168.0.2
Same as if its 10.0.0.1 make your pc 10.0.0.2
Then try connecting to the router using http://192.168.0.1 or http://10.0.0.1 or whatever it might be.
Your instructions should tell you the default address it uses.
Old Feb 9, 2005 | 10:47 AM
m1ke's Avatar
m1ke
it says to use 192.168.1.1
but i still got the same message when i tried that as well
Old Feb 9, 2005 | 11:03 AM
EssexBoyRacer
what have u set the ip address on u're machine to?
Old Feb 9, 2005 | 12:22 PM
m1ke's Avatar
m1ke
it is set obtain ip automatically, following instruction manual
Old Feb 9, 2005 | 12:25 PM
EssexBoyRacer
what operating system is your PC?
if its Windows 2000 or XP go to
START > RUN
then type CMD
Then in the black box that pops up type IPCONFIG
and it will tell you the IP address of your machine.
it should be 192.168.1.x (x could be any number between 2 - 254)
if its anything else then something is wrong.
Old Feb 9, 2005 | 12:30 PM
m1ke's Avatar
m1ke
ok will check it in a min
Cheers for the help its much appreciated
Old Feb 9, 2005 | 12:31 PM
EssexBoyRacer
no worries fella
Old Feb 9, 2005 | 01:01 PM
xpackcapri's Avatar
xpackcapri
Old Feb 9, 2005 | 01:12 PM
m1ke's Avatar
m1ke
just checked the ip address
its 217.41.58.147
Old Feb 9, 2005 | 01:14 PM
xpackcapri's Avatar
xpackcapri
Old Feb 9, 2005 | 01:55 PM
m1ke's Avatar
m1ke
It is the pc i am using now. At present it is connected via a speed touch modem, which works, but boss has just got a dsl-504t router so he (I) can connect the other pc to the net.
Connected it as the instruction book says, From wall jack to router, router to p.c via ethernet cable
Old Feb 9, 2005 | 02:10 PM
EssexBoyRacer
u need to find out what ip address u're getting when your router is plugged in.
Old Feb 9, 2005 | 02:25 PM
xpackcapri's Avatar
xpackcapri
Old Feb 9, 2005 | 02:59 PM
m1ke's Avatar
m1ke
Sorted
Cheers for all your help guys
Old Feb 9, 2005 | 03:01 PM
xpackcapri's Avatar
xpackcapri
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
paceo
Sep 25, 2015 08:05 PM
