Printer Help
Old Mar 29, 2004 | 12:43 PM
adamS2RST's Avatar
adamS2RST
Default Printer Help
Hi,
2 PC's running windows 2000 Both stand alone (not on LAN) One printer, linked to PC A directly via USB. PC B needs to print to this printer also. PC A and PC B are connected via a x over cable.
PC B can browse to PC A and when the printer is shared PC B can add the printer and print ok.
As soon as PC B log's off and logs back on, PC B has lost connection with the printer on PC A and it has to be manually added to the machine each time.
How can this be resolved? Also, don't want to "share" the printer as such as this means PC A (connected directly to printer must be turned on, but if this has to be done that is ok)
CheeRS
Old Mar 31, 2004 | 06:45 AM
Kanedaa's Avatar
Kanedaa
Strange...
Which service pack is installed?
Did you defined your printer as the default one?
Old Mar 31, 2004 | 02:52 PM
DanRSturbo's Avatar
DanRSturbo
The printer on pc a is shared all the time ? And is the printer installed as a default printer on pc b ??
Old May 23, 2004 | 08:02 AM
focusblues's Avatar
focusblues
you need to check the permisons on the PC hosting the printer and you may need the latest service pack (service Pack4)
Old May 23, 2004 | 09:05 AM
adamS2RST's Avatar
adamS2RST
na, solved this ages ago, nothing to do with it mate. AS it is 2K and on a workgroup not a domain you must have the same logon password on both machines for it to print properly.
dave1982rst
Apr 21, 2007 01:54 PM
adamS2RST
Computers, Consoles and I.T.
Nov 9, 2005 09:39 AM
markk
Mar 13, 2005 10:12 PM
