External Hard Drive - Knackered! help!
Old Dec 27, 2008 | 08:08 AM
Mike Kerbey's Avatar
Mike Kerbey
Default External Hard Drive - Knackered! help!
I have a external usb hard drive that doesnt turn on any more. It has its own mains power supply which is working and when i flick the on off switch on the hard drive, the "on" LED lights up on the front of the hard drive but the disc will no longer spin up.
What are my options for getting the data of the hard drive? and how much am i expected to pay?
Im a complete novice when it comes to computers etc.
Cheers!
Old Dec 27, 2008 | 08:14 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
I dont know the current going rate but just about every hard drive situation the data can be recovered.
Its not very often that the disk completely stops spinning though. Are you sure its not a power inside the box issue...
I would crack the box open and plug it in directly. Then atleast you would know its deffo the HD
Old Dec 27, 2008 | 08:24 AM
Aaroncast's Avatar
Aaroncast
-you backed it up?????? Didnt you-even a novice nows that!!
How old is it???--make and size???-
Old Dec 27, 2008 | 04:53 PM
Mike Kerbey
Ok, ill open the case and have a look, see whats going on.
Nope havent backed it up, bit silly i know!
Old Dec 27, 2008 | 04:54 PM
Mike Kerbey
I couldnt tell you the make, i bought it of ebay about 2-3years ago. Its 400GB though i know that!
Old Dec 27, 2008 | 07:28 PM
Mike Kerbey
ive taken the case off, and its a hitachi hard drive. Visually nothing looks wrong, everything is plugged securely etc, Im going to borrow a multi meter and check that the hard drive is getting power to it.
Old Jan 13, 2009 | 07:41 PM
Mike Kerbey
I got hold of a multi meter and i have power going to the board but nothing coming out to the motor on the hard drive itself. Just as it happens someone at work has the same external hard drive, and i measured the voltage on his, and his has 6v where mine has none. Im putting it down to a component failure on the PCB so im going to try and find a replacement board and try that.
Old Jan 16, 2009 | 08:03 PM
steve7786's Avatar
steve7786
Let us know how you get on as i have one that is doing the same. I stripped it out of the casing and tried it in the PC with no joy.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tib2220
Sep 14, 2015 12:33 PM
RSBryden
Sep 6, 2015 08:39 PM
