Virus help!! Trojan Problem
Old Jun 26, 2008 | 11:15 PM
Slevin Kelevra's Avatar
Slevin Kelevra
Default Virus help!! Trojan Problem
Ive got a fairly new PC with Vista on it.
I run Norton anti virus which is bang up to date.
Its detecting a trojan but cannot remove it.
Wndows Defender is the same.
The Trojan is Trojan:\win32\vundo.gen!H
I run adaware and its picking up at least 50 infections every time i use the internet.
What can I do to remove it?? NOrton want £70! to remotely clean my PC
Cheers!!
Old Jun 27, 2008 | 05:58 AM
Eagle's Avatar
Eagle
Super Moderator
http://forums.vnunet.com/thread.jspa...37637&tstart=0
download hijack this ... it logs all your startup info so you can post it up on security forums like http://forums.spybot.info/ ... they should be able to help you diagnose any issues
http://majorgeeks.com/download3155.html
http://www.hijackthis.de/
Old Jun 27, 2008 | 06:30 AM
Slevin Kelevra
cheers eagle!
Old Jun 27, 2008 | 06:55 AM
dojj's Avatar
dojj
Resident Wrestling Legend
i think i've got the same one
i haven't got around to deleting it yet as i've just disconnected the computer to the internet until i can get it sorted
Old Jun 27, 2008 | 07:01 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
How about starting the PC in Safe Mode, then scanning again. That sometimes works.
Old Jun 27, 2008 | 01:19 PM
Hockney's Avatar
Hockney
Very good online virus scanner http://housecall.trendmicro.com/uk/
Get rid of Norton and I recommend buying Kaspersky Internet Security http://www.kaspersky.com/
Old Jun 27, 2008 | 01:51 PM
Slevin Kelevra
cheers, ill try all that. I cannot choose which anti virus I use unfortunately
Old Jun 27, 2008 | 02:55 PM
Slevin Kelevra
Ok guys, house call has found MAL VUNDO 4.
I click remove but i get a warning saying if i delete this important files may be lost.
Will this f**k up my PC ??
Am i correct in saying that a tojan re writes the registry file?
Old Jun 27, 2008 | 03:00 PM
Hockney's Avatar
Hockney
Download, Install and Update Spybot and run the scanner http://www.safer-networking.org/en/index.html
or try http://vundofix.atribune.org/
Old Jun 27, 2008 | 03:03 PM
Slevin Kelevra
thanks for ur quick reply mate, so will i do this instead of clicking "Clean" in House call??
Old Jun 27, 2008 | 03:06 PM
Hockney's Avatar
Hockney
Yeah if your not to sure on just using that online virus scanner try the vundofix link, seems to do the trick going by what I've read thru googling Vundo
Old Jun 27, 2008 | 03:10 PM
Slevin Kelevra
ill download spybot
cheers again
Old Jun 27, 2008 | 03:15 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
install Linux, that will solve it
Old Jun 27, 2008 | 03:30 PM
Slevin Kelevra
ok, spybot has detected quite a few problems. Ive clicked fix and its now askind me to allow change or deny change. I take it ive to click Allow change but it keeps appearing for each entry. is this correct??
Old Jun 27, 2008 | 03:38 PM
_SpeedX_'s Avatar
_SpeedX_
if you want a very good setup which will stop everything then i recommend the following...
superantispyware pro
and mcafee enteprise edition.
my mate had a variant of vundo virus before the virus scanning software even detected it.
then few days later was in the dat files.
Old Jun 27, 2008 | 06:30 PM
Eagle's Avatar
Eagle
Super Moderator
you have to run it in safe mode to remove everything .. also turn of system restore .. or it reloads it easc time it reboots....
Old Jun 27, 2008 | 06:34 PM
DanRSturbo's Avatar
DanRSturbo
Format your machine and install Windows Xp. Then download and install AVG anti virus from free.grisoft.com.
Problems solved
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
