Windows Readyboost
Old Nov 18, 2007 | 06:31 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
Default Windows Readyboost
I know it is standard in Vista but can you download an add-on or something so it can be used on XP?
Old Nov 18, 2007 | 06:42 PM
Alex_86's Avatar
Alex_86
yap
here is a direct link:
http://www.eboostr.com/download/
Old Nov 18, 2007 | 10:13 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Its just a ram drive configured to use the memory of a USB solid state device... you can make a ram drive without buying any software.
A RAMDrive (or RAM Disk some people call it). This will dedicate a section of your computer's memory to the temporary storage of folders and files. Why would you want to do such a thing? Accessing time for files on a RAM Drive are about 1,000 times quicker than a conventional drive. Also, if you have a situation where you're access the same files over and over again, a ram disk will help reduce wear and tear on your real hard drive. Of course the down side of all this is that files on a RAM Drive are gone when the computer is shut down (or crashes).
There are some software packages out there that will configure a RAM Disk Drive automatically. If you need more bells and whistles, check those out. The following method is free and allows a RAM Disk of up to 32MB.
1. Download ramdisk.inf and ramdisk.sys file and save them in the same folder (somewhere convenient).
2. Go to the Control Panel and click Add Hardware
3. Click Next and wait for the search to complete.
4. Choose "Yes, I have already connected the hardware" and click Next
5. Scroll to the very bottom and highlight "Add a new hardware device" and click Next
6. Choose "Install the hardware that I manually select from a list" and click Next
7. Wait for the search to complete and click Next
8. Highlight "Show All Devices" and click Next (warning: this part may take a few minutes)
9. Click Have Disk... (Important! Be sure not to click on anything else or scroll through the lists before you click Have Disk. Doing so will screw up this process.)
10. Click Browse and locate the folder you saved the ramdisk.inf file in, select ramdisk.inf and click Open
11. Click OK, then Next and Next again.
12. Click Continue Anyway if a warning pops up and then Finish
Now for the fun part!
13. Under the Start menu, click Run, type in regedit and click OK
14. Open the following: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Ramdisk\Parameters
To set the size of the Ram Disk Drive, right click on DiskSize and choose Modify. Type in the new size under Value data. The maximum is 3,200,000 (in hexadecimal) which equals 32MB
15. If you need to, modify the DriveLetter enrty too. (the default is "Z")
16. Now navigate to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Fastfat
change the value of Start from 4 to 1
17. Exit the Registry Editor and Reboot
Old Nov 18, 2007 | 10:15 PM
Turbocabbie
Top Cab !!
A FREE ram drive can be found at the following URL :
http://members.fortunecity.com/ramdi...amdiskfree.htm
Old Nov 18, 2007 | 10:23 PM
Turbocabbie
Top Cab !!
I run a 4gb ram disk.. its called iRam by gigabyte
http://www.cluboverclocker.com/revie...-RAM/index.htm
Look at how fast Windows is on it ( Windows Reboot)
http://www.youtube.com/watch?v=1PiYgBhAkAM
(Windows Install)
http://www.youtube.com/watch?v=sts3Z...eature=related
Thats the real deal... not software emulated
Old Nov 19, 2007 | 02:07 AM
snedboy's Avatar
snedboy
Done all of above and installed free program thing and done all it asked and tbh my comp seems to run slower and boot up is alot slower
Where have i gone wrong??? Windows XP if that helps any!!
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
