Where can I get a TOSlink optical PCB header?
Like this - just the little black toslink "box" that I can fit to a PCB?
Basically, I have one of these;
http://www.maplin.co.uk/Module.aspx?...=97124&doy=5m3
But mines the later one without the optical audio output
Now, I took it apart and looked at the PCB inside - it still has the space and the holes in it for an optical toslink header.....
So, I was wondering if I got hold of the header itself, could I fit it to the PCB to see if the firmware still supported it?
Pic of PCB;
Optical header spot is far left, next to the VGA output...
Pic of PCB;
Found this on Google;
Toshiba TOTX173 - Farnell's site doesn't list them tho.... Don't know if the 177 will do the same thing mind.... Seems that TORX is a reciever (input) and TOTX is a Transmitter (ouptut)....
But can't order off that site Eagle posted - as minimium order os £20 excluding VAT
I thought that aswell - I have an optical soundcard, and they can be bought on ebay for less than a tenner - but a tenner is a lot of money if this don't work. And it's a lot fo money if I cannot remove the optical header from the soundcard with the pins intact
