Transfering files between PC's via ethernet/cat5 cable?
Old Feb 4, 2007 | 12:33 PM
Thrush's Avatar
Thrush
Irritating c........
Default Transfering files between PC's via ethernet/cat5 cable?
If you had two PC's, and coupled them together via LAN ports using cat5/ethernet cable, could you transfer files between them, and how fast would the transfer be?
IE, to send a 700mb AVI file from my PC to an external HDD connected by USB2 takes about 3 mins - would it be faster if sent to another PC via ethernet cable?
Old Feb 4, 2007 | 04:30 PM
nrg19uk's Avatar
nrg19uk
Default errmmmm
you would need a cross over cable if you was running them direct, transfer speed would depend which network cards you have most standard ones are 100mbs
Old Feb 4, 2007 | 10:34 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Default Re: Transfering files between PC's via ethernet/cat5 cable?
Yes it would be faster expecially with gigabit ethernet and the appropiate high speed cabling, however 3 minutes is not a long time to wait, use this a break from the pc and have a cuppa
Old Feb 4, 2007 | 10:53 PM
Thrush's Avatar
Thrush
Unseen - the USB2 is fine for transferring from the PC to the external HDD enclosure, but I am thinking when I move I might have a PC upstairs and one downstairs, so rather than trans from one to the external HDD, then from external HDD to the other PC, I was thinking linking the two PC's together - and I guess that USB cable across that sort of length isn't the best idea.... Don't know if you can even connect two PC's together via USB cable for file transfer.....
NRG - I though I would probably need cross over cable (something about the wires being linked to different pins?)
Each PC would have a 10/100 LAN card in them (one is a built in port and the other is a PCI card)
Old Feb 5, 2007 | 03:07 PM
Turbocabbie
Top Cab !!
yes you can usb network two pc's togeather... ethernet will always be faster through
the crossover cable works as follows
Old Feb 5, 2007 | 06:14 PM
nrg19uk's Avatar
nrg19uk
Default yup
just how unseenmenace has put, you can go through the mains of you house instead of having cables every where http://www.maplin.co.uk/module.aspx?...=46494&doy=5m2 with one of these they work well bit better than wireless
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
muz
Sep 30, 2015 08:29 AM
Bransby
Sep 14, 2015 08:54 PM
