Hard Disk drive problem
Old Apr 7, 2006 | 07:55 PM
glenis's Avatar
glenis
Default Hard Disk drive problem
Hi,
I have a 160GB HDD, which i recently formatted before installing windows from scratch.
When I plugged it back into the same machine, with windows running on a different drive.
Windows detects the drive as now only being 127GB.....
Before it showed in 'My Computer' has having 158GB...
Where has 21 GB gone, just because i formatted the drive ??
Please help, thanks
Old Apr 7, 2006 | 09:30 PM
Thrush's Avatar
Thrush
Irritating c........
What file system did you format to? From within Windows, you should be able to access the drive, and reformat it. Reformat to NTFS, and make sure there are no partitions...
Other than that, some motherboards can only use a maximum of xxxgb on a slave drive, so this might be the prob? I dunno too much about that tho....
Give the reformat a try. Should just be able to right click that drive and select FORMAT from the drop menu....
Old Apr 7, 2006 | 09:56 PM
glenis's Avatar
glenis
NTFS file system, as with all of mine.
Will try re-format again, but i am baffled
Old Apr 8, 2006 | 02:06 PM
Thrush's Avatar
Thrush
Lastly, check the jumper pin settings. Some HDD's have a setting for capped disc size.... Unlikely, but worth a look I guess....
Old Apr 8, 2006 | 02:21 PM
glenis's Avatar
glenis
Checked that, no luck
Old Apr 9, 2006 | 09:18 AM
DanRSturbo's Avatar
DanRSturbo
What did you use to format the disk in the first place ?
Old Apr 9, 2006 | 09:20 AM
glenis's Avatar
glenis
Windows XP installer, booted from windows XP CD
DOS type formatter, when loading windows on to a HDD from scratch
Old Apr 10, 2006 | 03:32 PM
adamS2RST's Avatar
adamS2RST
What sort of HDD?
I purchased a Maxtor 160GB drive last year and had to use a special program to get the disc to show correctly
Old Apr 10, 2006 | 03:47 PM
DanRSturbo's Avatar
DanRSturbo
Download the maxtor tool off their website
Old Apr 10, 2006 | 03:58 PM
adamS2RST's Avatar
adamS2RST
Yea, that's it, the large hard drive tool. Worked well for me.
Old Apr 10, 2006 | 04:48 PM
MikeyXR2i's Avatar
MikeyXR2i
Windows XP will only see 130GB on a fresh install on a massive Drive.
You can't get the remainder of the drive to be visible untill you actually install windows fully then mount it.
Old Apr 11, 2006 | 12:16 PM
BM08's Avatar
BM08
Now i didnt know that, good bit of info to try and remember for future reference
Old Apr 11, 2006 | 06:27 PM
Thrush's Avatar
Thrush
I don't quite follow Mike - eleaborate a little for me please?
Old Apr 11, 2006 | 07:31 PM
MikeyXR2i's Avatar
MikeyXR2i
Say for instance you buy a 300GB hardrive. Like mine, when you plug it in, your Bios will see it as 300GB or most bios's should anyway.
When you go to Install XP from your CD, during setup the program will check the new drive, but will only see 130GB's of it, thats all Windows XP setup will see.
Once XP is completely installed and running, you can actually setup the rest of the drive, make sure Service pack 2 is in etc, You go into Computer management, then disk management and setup up the rest of the space on the new drive for windows to see it.
Old Apr 13, 2006 | 06:53 PM
DanRSturbo's Avatar
DanRSturbo
That's only on IDE drives, SATA drives have the whole disk recognised
Old Apr 13, 2006 | 08:34 PM
Thrush's Avatar
Thrush
Oh okay.... But, if you already have a PC running XP on a 60gb drive, and you go and buy a 300gb drive and plug it in as a secondary drive - will windows see the entire 300gb?
Old Apr 13, 2006 | 10:09 PM
MikeyXR2i's Avatar
MikeyXR2i
No, it apply's to SATA as well. Windows XP Setup only see's 130 GB maximum, If you hardrive maker does a Utility to load into setup then your lucky.
Thrush, yes it will work that way.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muz
Aug 1, 2015 06:48 AM
